Topic: Motor shield voltage (Read 728 times) previous topic - next topic
dt85344
I have a motor shield on an Arduino UNO and when I activate the program the motors do not run properly. They are 9volt motors and only re cieving 5.6 volts. I have 9volts supplied to the external power on the shield and the jumper remuvedfrom the power pins. Is there a way to get 9volts out for each of the motors.
CrossRoads
Where is the 9V coming from - a square battery?
If you are not seeing 9V, the battery is either drained, or the motors take too much current.
dt85344
9volt power supply the voltage at the external power conecter on the shield remains at 9volts, motor 1 2 3 &4 drops to 5.6 when the motor is activated.
CrossRoads
Got a spec on the motor?
dt85344
No no spec on the motors thought the shield would take care of the curent problem. Guess I need to run them with  relays.
