Topic: recomendation on a board (Read 655 times) previous topic - next topic
paulalexpax
which is the best arduino board or combination of boards to use to control 2 stepper motors, 2 encoders, get data from a camera and transfer it to a remote computer and click the camera. basically i need to build a remotely controlled camera.
johnwasser
"Getting data from a camera" sounds like a job for a USB Host Shield
""Transfer it to a remote PC" depends on how remote the PC.  Can you run a wire?  Is it within WiFi range?  Is it within Cellular range?
Given the right shields you should be able to do it with an Arduino Uno.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
paulalexpax
the remote computer is trough wired connection. and i should be able to give commands to the board from my computer, that is the robotic cam should work in real time.
johnwasser
Connect the Arduino and a webcam to a small USB hub.  The Arduino will provide control over the steppers and the Webcam will provide real-time video.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
