Topic: Voltage regulators (Read 3926 times) previous topic - next topic
Gadget999
good idea on the picture !
i will send one in the morning  :)
Gadget999
here is a close up of the regulator and caps
here is the voltage on pin1 - input pin
here is the voltage on the output pin - should be 5 V !
any suggestions welcome
the power supply is my laptop power supply - i have another 20v supply, today when i plugged in the supply i noticed my wifes radio had a lot of noise that went when i unplugged it (not sure of this is relevant but i decided to use the laptop supply for this test)
Jack Christensen
#17
Oct 30, 2011, 07:12 pm Last Edit: Oct 30, 2011, 07:16 pm by Jack Christensen Reason: 1
The only thing that I can see is that the capacitor on the input side is connected backwards. The minus (-) lead on both capacitors should go to ground, i.e. the middle terminal on the 7805.
Not real familiar with what comes out of those laptop supplies, is there any particular reason you need to use one? I'd much prefer an inexpensive and much smaller and lighter wall wart similar to this one.
While the regulator will work fine on 18-20V input, without knowing how much current will be drawn by whatever the regulator will power, it won't take much current to cause the regulator to really heat up, because it has to drop 13-15V. So I might be prepared to heat sink it.
As for the radio frequency interference, was that something that was absent before, and now you're hearing it? Or was it just the first time a radio happened to be on. The laptop supply is no doubt a switching supply, so it could well generate some RFI. Or did you mean this laptop supply wasn't the one used before?
Grumpy_Mike
I noticed that the capacitors you use are not ceramic ones. A 0.1uF ceramic is a must in my book. The other thing is that you have no load on the output. For test purposes put a 1K or so on the output to draw a little current. And yes that cap is the wrong way round which might account for the interference.
Jack Christensen
#19
Oct 30, 2011, 07:48 pm Last Edit: Oct 30, 2011, 07:49 pm by Jack Christensen Reason: 1
Good points, Mike, I'd missed that. Actually I've gotten into the habit of using both ceramics and electrolytics on input and output. Might be overkill, but I figure it can't hurt. I'll use a larger electrolytic on the input especially if I'm not sure of the quality of the input power, e.g. from a wall wart, which is the situation in the attached schematic. Haven't ever had an issue with that approach. Also a clip from the National Semiconductor 78XX datasheet. Pretty sure I've checked these supplies with no load however, and the voltage is right where it's expected to be.
Gadget999
Thanks for the idea's guys
i fitted the cap the right way round and put a 1k for soem load
no change !
the noise from the power supply was something i had only noticed because the radio was on
do you think the noise may have damaged the regulators ?
Grumpy_Mike
Make the measurement from the center pin of the regulator to the output, not from the plug. It looks like the ground is not connected.
Jack Christensen
Well I'm fairly well flummoxed. Noise shouldn't hurt the regulator, unless its amplitude is in excess of the regulator's maximum rating, which would surprise me. Do you have anything else you can use for input? Like a wall wart that supplies 8-20 volts DC? Or just some batteries? Just try a 9V battery if you have one, or 5 or 6 AA cells in series. Use a new regulator and new capacitors if you have them. What are the values and voltage ratings of the capacitors you're using?
If your meter has the ability to test capacitors, check them out.
If it doesn't, you can still test to make sure they're not shorted as follows.
Set your meter to measure Ohms.
Take the capacitor out of the circuit.
Short the capacitor's leads together to remove any residual charge.
Connect the capacitor to the meter probes, matching polarity if it's a polarized capacitor.
What you should see is an initial low resistance, but it should then increase to at least several megohms as the meter's testing voltage charges the capacitor. For larger electrolytics, this may take several seconds, depending on the meter. For smaller values, e.g. ceramics, it will happen so quickly you may not notice the charging effect.
Gadget999
Bingo !
I checked the power between pins one and 2 and there was no voltage at all !
this confused me
when i studied the power socket it became clear !
the jack plug socket has 3 pins
1 +
2 -
3 -
i was using pin 2
so pins 2 and 3 are both negative. but what i did not realise is when you plug in the actual jack plug the pin 2 goes open circuit as the pin pushes the connector away  (i guess you can check continuity between 2 and 3 to see if the plug is in or not)
I completely overlooked this and now i look like an idiot ! (i certainly feel like one)
this has been a hard lesson
I would like to thank everyone for thier help particually Mike, It is easy to give up on a thread when somebody else is having some bother, your perseverance has helped me realise the problem
I was starting to think i was going nuts over this - and was going to test some regulators on another board then fit them to my project to try and see what had goe wrong - common sense was pointing to the noise on the power supply had killed the regs, But it was something very very simple
pleased i can press on now
Thanks again for your help
Grumpy_Mike
Quote
When ever you get into this situation, and it happens a lot even to me. I find that the problem is always that bit you think is obviously right. Knowing that helps but only if you persevere with it.
Now head long dash at full speed until you come to a screaming halt with the next snag. It's just like driving on the Autobahn on a Friday!
Jack Christensen
Indeed! Nice work, extra points for being remote!  :D
Njay
Be careful with electrolytic capacitors connected backwards. If you were really feeding 20V to the big one that was backwards, it would most probably have blown in under 5s.
westfw
BTW, while the capacitor advice was all "good", I don't think the 7805 regulators are known to be particularly fussy about their filter caps.  A ceramic output cap might have been better, but it shouldn't be "needed."
(some low dropout regulators are VREY fussy about the caps; check datasheets and follow recommendations.)
Grumpy_Mike
Quote
That is because they are more like high bandwidth amplifiers and with these it is possible to put too much decoupling capacitance on their output.
