Topic: motor bi-directionality issue (Read 1 time) previous topic - next topic
ahhreeyell
I have one of these (http://www.goldmine-elec-products.com/prodinfo.asp?number=G17949) motors connected to an H-bridge. It's part of a pulley system that lowers an object up and down on a string. It lowers the object down just fine; however, whenever I try to lift it back up again, the object gets stuck very easily, and lately the motor has begun to make a strange noise that I instinctively sense it should not be making.
Does anybody have any clue why? I'm running it off of the 5v supplied by the arduino.
ahhreeyell
Here's a photo of my setup, btw.
wildbill
Quote
Sounds like the first thing to try is more power, your motor likely needs more current than the arduino can provide when it's working harder (lifting). Also, it can take a rather higher voltage.
ahhreeyell
How would I do that if my whole H-bridge is connected to the Arduino? Could I use a 9v battery? How would I do that without messing up everything that's connected to the Arduino?
ahhreeyell
Can I just power the entire arduino using 9v?
zoomkat
Quote
Maybe for a minute or so. H-bridges usually have provisions for using an external power source for the gizmo being powered. 9v might be ok for only the arduino, but bigger batterys are needed for motors.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
CrossRoads
"Current drain unloaded is 0.46 Amps at 12VDC."
What H-Bridge are you using to power this motor?
