Topic: Arduino Duemilanove and Vmusic2 Not working (Read 1 time) previous topic - next topic
Can anyone see why my code would not be working?
Code: [Select]
#include <SoftwareSerial.h>
#define ledPinB 13
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  12;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  pinMode(ledPinB, OUTPUT);
  pinMode(buttonPin, INPUT);
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
Serial.print("VPF test.mp3");
delay(5000); //wait five seconds
Serial.print("VST"); //stop playing
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
Confirm your email address
Thank you for subscribing!
via Egeo 16
Torino, 10131
