Loading...
Pages: [1] 2 3 4   Go Down
Author Topic: Perpetual Hydro energy loop  (Read 2048 times)
West palm beach, FL
Offline Offline
Sr. Member
View Profile
Hey guys I am trying to make something which I am not sure if it is possible, it seems possible to me
Im thinking of placing a submersible water pump inside of  some sort of container filled with water
the water pump shoots out the water turning a turbine , the water is then collected and poured back into the water container so i will just keep reusing the same water and not have to refill.
The now turning turbine is connected to a wind/hydro generator or maybe even better some how geared up to several generators which all will be charging some 24v batteries...
the 24v batteries series (i think) with enough batteries of course will be what powers the water pump.
now i am thinking how to time it, or how many batteries to use or use reserve ones, where by the time one set of batteries powering the pump runs out the other set is done charging and power then switches and the dead ones begin to charge while the full ones begin to power..
generator : http://www.ebay.com/itm/Wind-Hydro-Generator-24V-Generator-135-Watt-Power-10-Amperes-3300-RPM-/280756349648?pt=LH_DefaultDomain_0&hash=item415e61ead0#ht_968wt_1163
pump: http://www.amazon.com/Wayne-RUP160-6-Horsepower-Oilless-Submersible/dp/B0009X8O2E/ref=sr_1_1?ie=UTF8&qid=1319893827&sr=8-1
turbine : http://www.ebay.com/itm/PELTON-TYPE-WATER-WHEEL-FLANGE-AND-NOZZLE-SET-HYDRO-TURBINE-/200667965390?pt=LH_DefaultDomain_0&hash=item2eb8be27ce#ht_1095wt_1163
Logged
I could print the Arduino logo on a box of cereal and sell it as "Arduin-O's"
West palm beach, FL
Offline Offline
Sr. Member
View Profile
actually since  i was thinking of buying this rollout solar panel
http://www.ebay.com/itm/SOLAR-Flexible-Roof-Panel-124-watt-UniSolar-/280722002063?pt=LH_DefaultDomain_0&hash=item415c55d08f#ht_1421wt_1139
maybe use that to charge the batteries during the day time and then ...hmm not sure but i would like to integrate that as well
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
Are you trying to get more power out of your turbine than you use to run the pump that drives the turbine?
Logged
Examples can be found at Learning in the Main Site and at the Playground
West palm beach, FL
Offline Offline
Sr. Member
View Profile
yes that would be the idea, maybe somehow hook up 2 generators to the turbine or more to make more then what the pump it self needs to opperate , i need to figure out how much current the pump draws to see how many batteries i would need to satisfy it.
Logged
Copenhagen / Denmark
Offline Offline
Edison Member
Do it !
View Profile
WWW
Since at system like this can not produce more energy than it consumes, as that would violate the first law of thermo dynamics, or the second, or both. I wonder what the purpose of the whole setup is?
Logged
New Jersey
Online Online
Edison Member
View Profile
You might want to take a look at this: http://en.wikipedia.org/wiki/Perpetual_motion
Logged
West palm beach, FL
Offline Offline
Sr. Member
View Profile
Quote
What if I connect one single turbine to some gears the turn MULTIPLE generators at twice, or more, the speed that the turbine is going would i not, with enough generators, produce more then what the pump consumes?
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
Eddie, the pump is *much* less than 100% efficient as is the turbine and the generator. Some, less than 50% efficient. At each step you lose energy so where does the extra come from? Wishful thinking?
Logged
West palm beach, FL
Offline Offline
Sr. Member
View Profile
Quote
Ok, but wouldn't the gears make up for the loss of efficiency? I could get gears to turn the generators who knows how many more times then the turbine
AND  multiple generators??? all with the same pumps, heck even add another turbine ...
Logged
New Jersey
Online Online
Edison Member
View Profile
If you don't like the laws of physics argument, try this: People have been trying to invent perpetual motion machines for hundreds of years - you're not the first to think of it. If it worked, wouldn't everyone have such a setup in their basement and the power companies be out of business?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
"In this house, we obey the Laws of Thermodynamics"
Homer J. Simpson
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
West palm beach, FL
Offline Offline
Sr. Member
View Profile
how do hydro electric power plants work? I must be totally wrong in my idea of how they work? Are they connected to the grid and then making electricity? which would be stupid unless they are producing more then they consume?
physics is not really my thing..sorry if i seem irrational
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
They are plugged into an even larger nuclear fusion energy system, conveniently and safely parked 93 million miles away.
There are some short-term hydro schemes which use off-peak generating capacity to pump water uphill to the reservoir, to be released to generate power during periods of peak demand, but there are losses.
« Last Edit: October 29, 2011, 09:51:29 am by AWOL » Logged
West palm beach, FL
Offline Offline
Sr. Member
View Profile
Quote
no because After a while people accept it is impossible and stop trying. we would still think the world is flat if it where not for those who  beg to question the knowledge of those even smarter then him who would swear they know the solution.
Logged
West palm beach, FL
Offline Offline
Sr. Member
View Profile
oh well i would still like to think it is possible some how some day, obviously not by me.
Logged
Pages: [1] 2 3 4   Go Up
Print
Jump to:
