Topic: Algorithmic symphonies (Read 990 times) previous topic - next topic
Ev0l
Inspired by http://countercomplex.blogspot.com/2011/10/algorithmic-symphonies-from-one-line-of.html I decided, hey my Arduino can do that. I have been playing with syntheses on the Arduino for a few months it looked like the perfect little project for a Saturday morning.
I decided easiest is best. Use Fast PWM and throw a lowpass filter on the PWM output to produce the sound. That way I don't have to deal with DACs or R2R ladders and all those pesky little wires. I have used the PWM/lowpass approach for sound generation with a great deal of success in the past.
I sourced the design for the low pass filter from http://interface.khm.de/index.php/lab/experiments/arduino-dds-sinewave-generator/. I did not have the exact values for the inductors but that does not appear to make much of a difference. You could also use a simple RC filter to filter and smooth out the output. RC filters are slightly simpler and if you don't have a couple inductors lying around will produce similar results.
So with out further bloviation here is the source code.
Code: [Select]
static char out = 255;
static int t = 255;
static int i = 0;
int count = 0;
ISR(TIMER1_OVF_vect){
  //The timer overflows at 62.5 KHz.
  //Algorithmic symphonies calls for 8khz
  // Throw a counter in there to slow things down.
  // It is also fun to play with the counter :-)
  //http://countercomplex.blogspot.com/2011/10/algorithmic-symphonies-from-one-line-of.html
  if(count < 7){
    count++;
    return;
  }else{
    count = 0;
  /** The best so far */
  out = (char)(((t>>6|t|t>>(t>>3))*10+((t>>11)&7))|(t)*(t>>14)|(t)*(t>>9))
              ^(63*(t/16) |(t%13) | (t%15))
              ^(16*(t/8));
  OCR1A = out;
  t++;
// Configures TIMER1 to fast PWM non inverted mode.
// Prescaler set to 1, which means that timer overflows
// every 16MHz/256 = 62.5KHz
void initPWM(void)
pinMode(9, OUTPUT);
// 8-bit Fast PWM - non inverted PWM
TCCR1A= _BV(COM1A1) | _BV(WGM10);
// Start timer without prescaler
TCCR1B = _BV(CS10) | _BV(WGM12);
// Enable overflow interrupt for OCR1A
TIMSK1 = _BV(TOIE1);
void setup(void){
  initPWM();
void loop(){
//Nothing to see here
I have attached a sound sample produced by the source code and a low pass filter schematic taken from the above mentioned URL.
I hope you find this as inspiring as I did.
Enjoy,
Will
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
