Topic: Arduino Uno on Ubuntu 10.10 (Read 1 time) previous topic - next topic
jambel
Hi I try to install arduino to a fresh Ubuntu 10.10 installation
I follow those instructions:
Quote
If you own an Uno or Mega 2560 and use Ubuntu 10.10
the Ubuntu repositories are a long way behind, so the default package in Maverick does not support those boards. Version 0018 of the IDE is from January 2010, the Uno and Mega2560 were released in September/October 2010.
To install, you have to enable the maverick-backports repository in the "Ubuntu Software Center" settings or do the following:
   1. Download the .debs for arduino, arduino-core, and librxtx-java into a clean directory from
      http://packages.ubuntu.com/maverick-backports/librxtx-java
      http://packages.ubuntu.com/maverick-backports/arduino-core
      (go down to the part that says "Download {package-name}" and choose your architecture or "all")
   2. cd to the directory you downloaded the .debs into and
   3. sudo dpkg -i *.deb
   4. you can delete the download directory if you'd like when you're done
but I get this error
Quote
Selecting previously deselected package arduino.
(Reading database ... 137121 files and directories currently installed.)
Unpacking arduino (from arduino_0022+dfsg-1~maverick1_all.deb) ...
Selecting previously deselected package arduino-core.
Unpacking arduino-core (from arduino-core_0022+dfsg-1~maverick1_all.deb) ...
Selecting previously deselected package librxtx-java.
Unpacking librxtx-java (from librxtx-java_2.2pre2-3~maverick1_i386.deb) ...
dpkg: dependency problems prevent configuration of arduino:
arduino depends on libjna-java; however:
  Package libjna-java is not installed.
dpkg: error processing arduino (--install):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of arduino-core:
arduino-core depends on gcc-avr; however:
  Package gcc-avr is not installed.
arduino-core depends on avrdude; however:
  Package avrdude is not installed.
arduino-core depends on avr-libc; however:
  Package avr-libc is not installed.
dpkg: error processing arduino-core (--install):
Setting up librxtx-java (2.2pre2-3~maverick1) ...
Processing triggers for desktop-file-utils ...
Processing triggers for python-gmenu ...
Rebuilding /usr/share/applications/desktop.en_US.utf8.cache...
Processing triggers for man-db ...
Processing triggers for doc-base ...
Processing 2 added doc-base file(s)...
Registering documents with scrollkeeper...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Processing triggers for python-support ...
Errors were encountered while processing:
arduino
arduino-core
john@Soprano:~/Desktop/untitled folder$ sudo dpkg -i *.deb
(Reading database ... 137990 files and directories currently installed.)
Preparing to replace arduino 0022+dfsg-1~maverick1 (using arduino_0022+dfsg-1~maverick1_all.deb) ...
Unpacking replacement arduino ...
Preparing to replace arduino-core 0022+dfsg-1~maverick1 (using arduino-core_0022+dfsg-1~maverick1_all.deb) ...
Unpacking replacement arduino-core ...
Preparing to replace librxtx-java 2.2pre2-3~maverick1 (using librxtx-java_2.2pre2-3~maverick1_i386.deb) ...
Unpacking replacement librxtx-java ...
Processing 2 changed doc-base file(s)...
arduino
arduino-core
(Reading database ... 137194 files and directories currently installed.)
arduino
arduino-core
any solution?
SurferTim
You might want to check the repository again. Ubuntu should have the new version by now.
But the packages you are missing:
Quote
hugo007
#2
Oct 31, 2011, 11:07 am Last Edit: Oct 31, 2011, 04:24 pm by hugo007 Reason: 1
Hello
Just read this pagehttp://www.arduino.cc/playground/Linux/Ubuntu and download the .deb files and then install
After download all then just do "sudo dpkg -i name_of_package.deb"
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
