Topic: I2C question (Read 721 times) previous topic - next topic
dudevlad
I am currently getting some data from a Libelium GPS on the Arduino and all the data must be sent on i2c to a windows pc. Can all the array be sent in only one i2c write or each item of the array must be sent separately?
Best regards, Vlad!
nickgammon
I wasn't aware you could use I2C to talk to a Windows PC. What hardware are you using to do that?
Given that it is possible, internally the Wire library has a 32-byte buffer (unless you change the library) so you would be limited to sending 32 bytes at a time.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
dudevlad
I am using a RoBoard110 as the master on the i2c.
Grumpy_Mike
Quote
What ever you like, you design the protocol when you make the arduino an I2C slave.
