Loading...
Pages: [1]   Go Down
Author Topic: what circuit layout does capsense use?  (Read 1044 times)
Oregon
Offline Offline
Newbie
View Profile
Using capsense library with multiple inputs, do you use this layout?
Or this one?
Or something else?
edit:  On the second drawing I meant to have the third input after the resistor.
« Last Edit: October 30, 2011, 05:14:17 pm by aefields » Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
If you look at the demo sketch on http://www.arduino.cc/playground/Main/CapSense you will see that it describes the circuit for a single send pin and multiple receive pins:
Code:
CapSense   cs_4_2 = CapSense(4,2);        // 10 megohm resistor between pins 4 & 2, pin 2 is sensor pin, add wire, foil
CapSense   cs_4_5 = CapSense(4,5);        // 10 megohm resistor between pins 4 & 6, pin 6 is sensor pin, add wire, foil
CapSense   cs_4_8 = CapSense(4,8);        // 10 megohm resistor between pins 4 & 8, pin 8 is sensor pin, add wire, foil
One resistor per sense pin.
Logged
Sussex UK / CT USA
Offline Offline
Edison Member
Forums forever
View Profile
WWW
'Way down at the bottom of....
http://sheepdogguides.com/arduino/art3capsen.htm
.. you'll find a diagram... red, teardrops.
(Other stuff in that may help, too.)
Logged
Pages: [1]   Go Up
Print
Jump to:
