Topic: Do all ICs need regulated voltage?IC data sheet tutorial (Read 2896 times) previous topic - next topic
prowler_sn
does an ICs input voltage have to be regulated or can one just hook without one?
and does anyone know a good source where i can find tutorials on how to understand the IC datasheet.
thnx in advance.
cheers
Noorman
The majority of IC's need a stable powersource to function properly.
This is all dependent on the function and use of the IC.
I would advise you to read a lot about basic electronics and principles.
On the net there are loads of tutorials etc.
This way you can gain knowledge about electronics and recognize the specs that are use in the spec. sheets of IC's.
Unfortunatly there is no shortcut to obtain knowledge :-)
Happy reading...
winner10920
U should try it without regulated and see if it works accuratly and well, sometiems its fine and sometimes what you have is enough, just don't forget about it if you are getting glitches that its one possibility to check
pekkaa
Quote
Instead of just trying and watching what happens, I strongly suggest that you take the time and learn to read the datasheets. It you power the chip from out of the range or unstable voltage, it may seemingly work for a while, but can damage the chip and stop working if you do a slight  change in the configuration.
pekkaa
If you post here the IC's part number and link to the datasheet, someone here may even help you to interpreter the datasheet.
maniacbug
Hmm, so let's take an example.  ATMEGA328P-PU running on 3 AA's and no regulator.  Is there something in the data sheet which advises against this?  I couldn't find it, but since we're on the topic I thought I'd ask.
pekkaa
Power from AA batteries is inherently more stable that what you get e.g. from a wall wart.  An unregulated nominally 12V wall wart may provide several volts more when the load is very low.
CrossRoads
Section 28 (I think) of the data sheet has a chart showing the acceptatble voltage for operation at different clock frequency.
Earllier it has a chart showing Hi/Lo voltage at different current levels wlth different Vcc levels.
Reading the chart, you fill 16 MHz operation at 4.5V is well within the acceptable range for  both voltage level and frequency.
Just about any switching regulated wallwart will work fine also.  www.dipmicro.com carries several at 4.5V & 5V at different current capacities to support your arduino and the external loads. Or go slightly higher (7.5V) if you want to plug into the barrel jack vs connecting to the 5V & Gnd pins on the power header.
Grumpy_Mike
Quote
Rubbish. You always need to use capacitors. Take that as a rule and you won't ever go wrong. The occasions where you might think you have "got away with it" are illusory and often short lived.
Why is it that beginners on this forum are afraid of capacitors? They cost next to nothing and are vital for a stable noise free supply.
cmiyc
Why do people drive an automobile fast before they have mastery of how it operates?  Because it is easier and (seemingly) faster.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
cr0sh
I learned to drive quite late in life compared to most people, when I was 21 (I had some classes in high school - but I didn't do well, except on the freeway, strangely). My (now) wife taught me when we were dating. She taught me on dirt roads that were around her house out in the desert here in Arizona. She told me to take the car up to 25 mph. I had never been in a car with a tach. I don't think she'd ever driven at 25 hundred RPM on a dirt road, either...
:D
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
prowler_sn
Quote
can u please explain why is it better to attach caps to the regulator. i have read that its "better". no one explains why.thanks in advance
CrossRoads
Regulator spec says so:
"It is not necessary to bypass the output, although this does improve transient response.
Input bypassing is needed only if the regulator is located far from the filter capacitor of the power supply. "
So puta 0.1uF on the output, make your circuit happy.
CrossRoads
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00000447.pdf
Look at all the varieties of things you can do with a 3 terminal regulator here - and all have caps.
