Loading...
Pages: [1] 2 3   Go Down
Author Topic: Try FreeRTOS - compare with ChibiOS/RT  (Read 10692 times)
0
Offline Offline
Edison Member
Arduino rocks
View Profile
I have posted a port of FreeRTOS here http://code.google.com/p/beta-lib/downloads/list.  The file is FreeRTOS20111031.zip.
There is also a port of ChibiOS/RT posted as ChibiOS20111027.zip.  See http://arduino.cc/forum/index.php/topic,76932.0.html.
I have attempted to use the same options in both ports.
I used timer 0 for the system timer so the OS tick time is 1024 usec or 976 Hz.
I provided the same five examples in each port.
Quote
There are five examples in the FreeRTOS/examples folder.
frBlinkPrint - A simple example of three threads. A high priority thread
               blinks an LED, a medium priority thread prints a counter
               every second, and the low priority idle loop increments the
               counter.
frContextTime - Test to determine context switch time with a semaphore.
frFastLogger - Data logger optimized for 328 Arduino.  Logs two analog pins
               every two ticks (1024 usec tick).
frJitter - Test of jitter in sleep for one tick.
frMegaLogger - Data logger optimized for Mega.  Logs four analog pins
               every tick (976 samples per sec, four values per sample)
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
Quote
I have posted a port of FreeRTOS ...
So what are YOUR observations?
I'm looking at those new ARM chips (and similar) with 1M of flash, and also concluding that it doesn't make sense to start working on them without some sort of kernel underneath.  If they were "real" computers (with MMUs), some form of linux would be an obvious choice.  These "in  between" chips (too big for a monolith, too small for linux) are a puzzle.  "Free" seems pretty important.
The logical conclusion is that the 2560 on the MEGA is in a similar situation.  A single 256k program is ... not desirable (though I'll concede that there are some smaller efforts with lots of data that could make use of that memory...)
Are there non-real-time alternatives as well?
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
I didn't comment much on FreeRTOS because I like to do things that are fast and there is this restriction:
Quote
FreeRTOS may not be used for any competitive or comparative purpose, including the publication of any form of run time or compile time metric, without the express permission of Real Time Engineers Ltd. (this is the norm within the industry and is intended to ensure information accuracy).
FreeRTOS is popular, runs on lots of chips/boards and there are books and support.  For several reasons it is not my favorite of systems I have tried.  I don't like the fact is only uses dynamic memory.
Be sure to look at the semaphore context switch examples on a scope.  There is an amazing difference.
I like ChibiOS/RT, it is extremely fast, small and uses RAM very efficiently.  The author of ChibiOS/RT, Giovanni Di Sirio, has a design/coding style that I like.
A much better recommendation is here http://www.yagarto.de/projects/chibios/index.html.  Michael Fischer is a true expert in ARM.  I use his YAGARTO tool-chain on ARM.  He discusses six popular RTOSes in this link.
Also here http://www.yagarto.de/projects/rtoscomp/index.html.
« Last Edit: November 03, 2011, 12:54:28 pm by fat16lib » Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
We did have a discussion thread on RTOSs a month back, and the conclusion was they were a total waste of time especially in the arduino context.
They just suck the power out of a processor and move the debugging process into the fighting the RTOS region.
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
I have no interest in discussion.  Did anyone do a serious application that is difficult without a RTOS.
The Chibios/RT Mega data logging example has a 15 usec overhead for the context switch to the ADC task.  It takes 110 usec for each analogRead so the overhead is small.
The logger example can read four analog pins every 1.024 milliseconds, format them as CSV text, and write the data to an SD without missing points.
SD cards can have occasional write delays of 200 milliseconds so there can be well over 100 context switches to the ADC task while a block is being written to the SD.
I have done special timer based sketches to do loggers like this but ChibiOS makes it easy.  Context save/restore can be faster in a custom solution but that speed is not required when using analogRead().
This example can log data about 100 times faster than a simple loop that does four analogRead() calls and then writes the data to the SD using print.
In this example a context switch happens every 1024 usec and takes 15 usec so the overhead is about 1.5%.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
OK bye bye  smiley-razz
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Sorry, by discussion, I meant without facts.  Too much of the stuff in forums is just opinion.
I believe in the old saw sometimes attributed to Admiral Grace Hopper.
Quote
“One accurate measurement is worth a thousand expert opinions” - Adm Grace Murray Hopper ( Dec 9 1906 to Jan 1 1992)
She also coined the term "bug".
Here are a few more of her quotes http://womenshistory.about.com/od/quotes/a/grace_hopper.htm.  Not bad for someone who started programming in 1944.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Well I don't know what you mean by facts but I have been in electronics / micro controllers professionally for over 40 years. I have as a manager had to run projects both with and without an RTOS so I have seen what actually happens.
Normally it is the software engineers initially push to use an RTOS with the expectation of an easy life. Very rarely does it happen like that because the problems encountered with the project then appear to be related to exactly how the RTOS is working and how to get it to do what they want. In the mean time the extra resource in memory and CPU cycles means you have to go to at least the next processor up as the power and capacity is drained by the RTOS.
In the end the project works although about four times the effort has gone in to the project and the hardware is more expensive.
Not using an RTOS on the other hand forces the programmer into actually thinking and planning what they want to do, something that is not always popular with them. However I have found that non RTOS projects come in faster and have a less demanding CPU requirement. The actual system is often more responsive as well.
Of course some projects are so large and have many programmers working on them that an RTOS is almost mandatory. However for small projects I have found them to be totally useless.
Your specific question:-
Quote
Yes I have managed and contributed to these. The largest project was an Enterprise scale access control system with up to 256 nodes spanning buildings covering an area of over three square miles. I think that ticks all your boxes for that one.
Quote
The point is that what ever you can do with an RTOS you can do without it, usually much faster.
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
View Profile
Quote
Ah, but we already went to the "next processor up" when the m328 became standard.  And then the MEGA, and the MEGA2560, and now we're looking at seeing the next stage beyond that.
Quote
About how much object code?  When you say you didn't use an RTOS, does that mean no  multitasking at all, or just no OTS well known RTOS?  There's so much of "modern computing" that is deeply dependent on "tasks" that I wouldn't want to try to do it without some OS.  Most of Networking, for instance.  cisco routers ran an OS back in the day when they had 512K of memory; I can't imagine having implemented what they did without the OS.  And an STM32F4 eval board is a candidate for an Arduino environment, and has MORE memory than that...
Quote
But we rapidly approach an era where memory and CPU cycles are SO cheap...  An Arduino Uno is overpowered for many of the tasks it is put to.  The hypothetical Arduino Due is ridiculous.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Well we went up to another pin compatible part with the same CPU horse power. The problem on a commercial project is when this happens you have to scrap all the existing prototypes and try and claw them back.
Quote
It was just over 100K when compiled.
Quote
You don't need an RTOS to do multitasking, you just need to design your code correctly.
Quote
That is an argument that I first came across 30 years ago, it is as true now as it was then.  smiley-wink
Quote
So lets cripple it with a RTOS?
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Grumpy_Mike,
Please share some facts with us.  Please provide numbers from any measurements that prove these statements.
Quote
Which processor and RTOS/version does does the above refer to?  Why did you allow a RTOS to used?  Didn't you do prototyping as part of the decision process?
Quote
What percent of cycle go to the RTOS and where in the RTOS?  Which processor and RTOS does this refer to?  What is the nature of the application that causes so much overhead in the RTOS?
Quote
How do you decide when a RTOS is useless?
Quote
What techniques do you use that can't be done by a RTOS?  Which RTOSes did you benchmark to prove that roll you own was required?
Quote
The processor in the Due was designed for use with a RTOS.  Why do you think it will be crippled?
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
View Profile
Well, on Mike's side, I've seen RTOS vendors recommend things like using a UART ISR to merely send a message to wake up the actual driver, which would then do the actual reading of the data from the uart.  This can make sense from a "strict real time" point of view, and might be OK for an OS with a complex tty driver, but for the typical Arduino-class serial driver it would be insane (IMNSHO.)  If you use an RTOS, you can spend a lot of time making this sort of decision, and bending code in "unnatural" and ultimately inefficient ways, just to fit the capabilities and style of the RTOS in question.  It all ... depends.
It's sorta like C++ and Java programming for the desktop being more about learning the existence and capabilities of a multitude of classes and libraries than learning the language itself.  (Sometimes I worry that Arduino is also headed that way.)
In what way is ARM CM3 "designed for use with an RTOS" ?  I'd rate most RISC microcontrollers, with their large register sets and relative small amounts of RAM, as being generally poor choices  for RTOS or even multitasking.  Too much context and not enough place to save it...
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
westfw,
Here is an example that shows why the ARM CM3 architecture is very RTOS friendly.  The example is a bit long.  I will use the internals of ChibiOS to illustrate.
The context for the ARM Cortex M3 is divided into two parts.  ChibiOS refers to the first part as the Interrupt saved context.  This part of stack frame is eight 32-bit words and is saved by the NVIC, Nested Vectored Interrupt Controller, when an interrupt occurs.
Here is the structure in ChibiOS:
Code:
struct extctx {
  regarm_t      r0;
  regarm_t      r1;
  regarm_t      r2;
  regarm_t      r3;
  regarm_t      r12;
  regarm_t      lr_thd;
  regarm_t      pc;
  regarm_t      xpsr;
The remainder of the context can be saved by a single instruction if a context switch is required.  Here is the structure for that part of the stack frame in ChibiOS:
Code:
struct intctx {
  regarm_t      r4;
  regarm_t      r5;
  regarm_t      r6;
  regarm_t      r7;
  regarm_t      r8;
  regarm_t      r9;
  regarm_t      r10;
  regarm_t      r11;
  regarm_t      lr;
Here is the context switch function that is called by ChibiOS at the ISR level if a context switch is required.
Code:
#define PUSH_CONTEXT() {                                                    \
  asm volatile ("push    {r4, r5, r6, r7, r8, r9, r10, r11, lr}"            \
                : : : "memory");                                            \
#define POP_CONTEXT() {                                                     \
  asm volatile ("pop     {r4, r5, r6, r7, r8, r9, r10, r11, pc}"            \
                : : : "memory");                                            \
__attribute__((naked))
void port_switch(Thread *ntp, Thread *otp) {
  PUSH_CONTEXT();
  asm volatile ("str     sp, [%1, #12]                          \n\t"
                "ldr     sp, [%0, #12]" : : "r" (ntp), "r" (otp));
  POP_CONTEXT();
When you write an ISR you decide if an event has happened that requires a task to be triggered.  In a USART handler this could be an end of message character.  If you have not received this character there is no overhead.
If you receive the end of message character, you call a ChibiOS routine and it checks if a context switch is required and does the above stack switch if necessary.  When you return from interrupt the rest of the context switch will occur in the NVIC.
On a 72 MHz STM32 the overhead for this call with a context switch is about 2 microseconds.  Most of this time is in determining which task should run, not the context switch.
I have made this as simple as possible so I am sure you will have a "but what if?".
Logged
Rapa Nui
Offline Offline
Edison Member
Pukao hats cleaning services
View Profile
..I've seen on a different forum (avr, arm, pic etc.) an interesting thread - a guy is asking for a help as he need a debugger (for STM32VL) which steps similarly as on AVR at asm instructions level. The other guy is answering him that the STM32 is a different league and nobody needs that actually.. and if the application is seen demanding he has to take simply a STM32 with a higher clock frequency..
An interesting point. I think the debate on rtos vs. superloop is similar - it is about productivity..
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
pito,
There are lots of ways to solve a multitasking real time problem.  The solution must satisfy this condition:
Quote
Real-time means it reacts in a timely fashion, i.e. fast enough for the task at hand.
But this must also be true of the tools you use.
Quote
You can however only use it productively and safely if you understand how it works and what the limitations and pitfalls are.
Super-loops are simple so they are great for most programmers if they satisfy the real-time requirement.
Preemptive RTOSs have pitfalls that trip up the inexperienced and are probably not the best choice for most hobbyists.  This may not be for you if you don't know what priority inversion is or the difference between a semaphore and a mutex.
Here is a nice article about multitasking alternatives http://www.splatco.com/rtos_1.htm.
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
