Topic: 12 V Regulator (Read 1 time) previous topic - next topic
arduinopro
Hi. I'm using a 12 V regulator to power some computer fans. Is it necessary to use capacitors with the regulator or will it be fine without them. Thanks.
James C4S
In general, you should use what the datasheet says.
If a (relatively) constant load like a fan is present, they are probably not necessary.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
Grumpy_Mike
Quote
Yes they are.
Anyway a fan is inductive and noisy so you defiantly need them with a fan.
There has been a flurry of these posts recently, I don't know what caused it but if any professional electronic engineer insisted in not putting caps on regulators he would be sacked, and quite rightly.
arduinopro
Thanks. The data sheet says nothing about capacitors. What amount should I use?
Grumpy_Mike
I doubt that can you link the data sheet?
Grumpy_Mike
Page 2 second paragraph. They say 0.33uF, and all the example circuits have 0.1uF on in and out.
arduinopro
floresta
Quote
There has been a flurry of these posts recently, I don't know what caused it ...
It's a conspiracy to rile you up.  They switch back and forth between voltage regulator capacitors, bypass capacitors on ICs, and the capacitor on the shift register clock line.
Don
