Loading...
Pages: 1 2 [3]   Go Down
Author Topic: TLC5940 Overheating (Daisy Chain) ( Electronic Beer Pong Table)  (Read 2177 times)
Offline Offline
Edison Member
Now, More Than Ever
View Profile
So what has changed since the last session?
Was everything likewise smoothly going in past sessions, too?
Logged
Don't React -- Read!
Texas
Offline Offline
Newbie
View Profile
Since the previous sessions (Fried IC's), I have added multiple 1uf and 100uf Capacitors along the railings. I didn't expect it to work as flawlessly as it did!
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
So, you've exceeded past run times now and heat is a thing of the past?
Logged
Texas
Offline Offline
Newbie
View Profile
Yes, the past run times were from 5 to 40 minutes. I'm going to call Texas Instruments tomorrow to verify that the Max Ouput of 120mA is for a single OutX. I'll let you guys know.
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
I guess it's a take at this rate.
I hope you don't figure that I'm "against you" or anything like that.
If it hangs in there and everything is everything then good on you.
Thermal runaway for lack of some bypassing...[scratches head, mutters]...
Here's hoping somebody at TI takes that call and can give a definitive answer on what constitutes "Absolute Max" (pkg, output, per output, or what.)
Logged
Texas
Offline Offline
Newbie
View Profile
Thanks for the help and concern, I appreciate it!
Logged
Offline Offline
Jr. Member
View Profile
"BTW....since dot correction was not stated as being used, DCn=0."
No way!  Does nixing pixel correction imply 0, does the datasheet state that?  If that was so, as you noted, then you could do whatever you wanted because everything there gets multiplied by "0/63=0" and everything would then be "0", a free play, and that would make zero sense.
Yes, the datasheet does talk about dot correction being in the range of 0 to 63 or 64 steps from 0% to 100% of the maximum output current Imax (page 15).
Review Order of math operations: http://en.wikipedia.org/wiki/Order_of_operations then apply it to the equation.  It doesn't make the whole thing zero...just everything past the '+' sign. smiley
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
I get your "argument", Cranium, but your contention that not using dot correction results in DCn/63 = 0, implying a free pass on the consequences of everything to the right of the addition sign, is false.
If it's not specified then DCn/63 = 1 (nothing gets turned down for matching.)
If DCn/63 = 0 then the output would be off .
Yes, Page 15 --
Setting Dot Correction:
I_out = I_maxA * (DCn / 63)
If DCn/63 = 0, then I_out = 0.
A - R_iref (Pg. 14)
Logged
Offline Offline
Jr. Member
View Profile
Yes, Page 15 --
I stand corrected.  You are right on this point. smiley
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
