Topic: Leadshine Microstep driver m325 (Read 4147 times) previous topic - next topic
vleud101
Hi guys,
I try to hook up my micro-step driver at my Arduino UNO board. But i got the problem i have only the basic knowledge of electricity.
The manual of it is this PDF : http://www.cncshop.cz/PDF/M325.pdf
Is it the best way to use PWM for it? I already searched at the internet about this case, but cant find anything similair.
Thanks for the help!
(p.s. my main language is dutch, sorry for my English!)
Grumpy_Mike
Quote
No PWM should not be used.
It is a stepping motor controller, wire it up as shown in Figure 3.
vleud101
#2
Nov 01, 2011, 08:57 pm Last Edit: Nov 01, 2011, 09:03 pm by vleud101 Reason: 1
Thank you for replying! :)
Ok,
I put: VCC to +5V
Pul to ...
Dir to...
Enable ( dont need to use )
Grumpy_Mike
The pul is pulse the dir is direction you connect them to any arduino output pin. The dir controls the direction of the motor and a pulse on the pul advances the motor by one step.
vleud101
Ok,
Thank you!
I go test it, and do some more research on the internet
vleud101
Ok i did it, for the people who googling this topic and have the same prob. I did somting stupid, i downloaded the wrong image of the wire collers from my motor..  :smiley-roll-sweat:
Now if i just send a puls (200 for 180 degrees) its working perfect (put switch 5-6 on) 800 for switch on 5-6 off!
Thanx alot again ;)
