Topic: Usage of the MAX488 as a MAX485 (Read 2688 times) previous topic - next topic
LuisSoares
I ordered the MAX488 to comunicate through RS-485 using Modbus RTU protocol.
Now i have noticed that the MAX488 is full duplex chip ( http://datasheets.maxim-ic.com/en/ds/MAX1487-MAX491.pdf ) which makes me use 4 lines of comunication and separate the Data IN and Data OUT chanels.
Is it possible to use the MAX488 like a MAX485? Using only 1 diferential channel and copying the connections like they are made for the MAX485 in the datasheet?
Does anyone know?
Best regards
Grumpy_Mike
I think not because you do not have a ~RE pin on the MAX488 that means you can't control which way the simplex communications is operating in.
A lot depends on the actual application you are trying to do.
Graynomad
With the 488 I think you are out of luck, for half-duplex you need to disable the transmitter and that's not possible with the 488.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
