Topic: Level Shift 5 & 3.3 (Read 1 time) previous topic - next topic
magnethead794
Nov 17, 2011, 07:57 am Last Edit: Nov 17, 2011, 05:28 pm by magnethead794 Reason: 1
Converting system from the Mega down to the Pro Mini 5V. I think I blew the 3.3 Regulator on my Mega by I2C'sing 3.3 and 5V together.
4" x 6" double sided perfboard
Arduino Pro Mini 5V 16Mhz
3.3V 0.8A Voltage Regulator
5.0V 1.0A Voltage Regulator
BMP085 Barometer/Temperature Sensor
HH10D Hygrometer
BlueSmirf RP-SMA
DS1307 RTC
2x I2C Level Shifter
The power source is 9VDC nominal.
The BMP085 is 3.3V I2C.
The HH10D is 3.3V I2C with a frequency output for data processing.
The DS1307 is 5.0 V I2C.
First question: How can I correctly I2C the voltage mixture? Since I'm using a 5V board, do I run the BMP085 and HH10D through the level shifter to bring them up to 5V, or do I run the DS1307 through it and bring it down to 3.3V? i am assuming the former?
Second Question: Can I just connect the +5 of the Mini, VCC of the DS1307, and VCC of the BlueSmirf to the 5 volt regulator, and the BMP085 and HH10D to the 3.3V regulator? That way I don't have to worry about current consumption through the board itself, all it has to do is take in the I2C lines and the frequency output of the HH10D.
madworm
Seems like you need a bi-directional level shifter for the 2 low-voltage I²C devices.
Google for "AN97055". A very useful document!
Edit: seems like the sparkfun thing will work. The appnote explains how it works in great detail.
magnethead794
Do I need one shift board per sensor, or can I combine both 3.3V sensors, and just use one shift board to jump to 5V with the I2C from the clock?
magnethead794
I'm assuming I can combine the 3V3 sensors, but would like conformation so I can alot space on the board..
runaway_pancake
The app_note mentioned by madworm shows how to make your own 3V-5V interface, so does the sparkfun board's schematic.
Providing each I2C device has its unique address then they can share SDL and SCK.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
