I have a MEGA 2560 : External Interrupts: 2 (interrupt 0), 3 (interrupt 1), 18 (interrupt 5), 19 (interrupt 4), 20 (interrupt 3), and 21 (interrupt 2). These pins can be configured to trigger an interrupt on a low value, a rising or falling edge, or a change in value. See the attachInterrupt() function for details.
I amtrying to generate a interupt on the rising edge of a sine wave. I im running the code below, but im having problems with the innterupts. only intterupt 2 seemed to be working (Timer interrupt DOES work fine). I know this because if i change the inerupt number between my 2 interupts only the one connected to pin21 (interrupt 2) works. The other is always a factor of 10-100 times faster than it should be.
I have an LCD connected.
#include <TimerThree.h>
// These constants won't change. They're used to give names
// to the pins used:
const int WindInPin = A0; // Analog input pin for the Wind direction – Potentiometer
const int TurbineInPin = A1; // Analog input pin for the Turbine orientation – Potentiometer
float maxallow = 0.0;
int degout = 0;
float K = 0.0;
float direc = 0.0;
float error = 0.0;
volatile int count3 = 0;
volatile float WindMS[10] = {0,0,0,0,0,0,0,0,0,0};
volatile float TurRPM[10] = {0,0,0,0,0,0,0,0,0,0};
volatile float sumTurRPM = 0.0;
volatile float sumWindMS = 0.0;
volatile float turrpm = 0.0;
volatile float windms = 0.0;
volatile int Count1 = 0;
volatile int Count2 = 0;
const float CRMP = 367.4;
const float k1 = 22.33;
const float k = 0.708;
const float k2 = 0.763;
const float pi = 3.14;
const int analogOutPin = 9; // Analog output driver is attached to this pin
int WindValue = 0; // value read from the Wind direction – Potentiometer
int TurbineValue = 0; // value read from the Turbine orientation – Potentiometer
int outputValue = 0; // value output to the PWM (driver - analog out)
// initialize serial communications at 9600 bps:
attachInterrupt(1, WindSpeed, RISING);
attachInterrupt(2, TurbineRPM, RISING);
// Timer3.attachInterrupt(Second);
backlightOn();
// read the analog in value:
// Timer3.initialize(1000000);
WindValue = analogRead(WindInPin);
TurbineValue = analogRead(TurbineInPin);
error = WindValue - TurbineValue;
if (error < 0.0){
error = error*-1;
direc = 0.0;}
direc = 1.0;
if(turrpm>0.0)
maxallow = CRMP/turrpm; //Maxallowin RPM
maxallow = 0.0 ;
//convert to motor max RPM /50 for gear ratio and max
if((error >= 10.625) || (maxallow >= 6.67)) // bigger than 15deg or maxallow speed
maxallow = 335.0;
maxallow = maxallow*50;
degout= error/k;
if(degout < 2)
maxallow = 8.33;
else{
degout = degout-1;
maxallow = degout*k1;
//convert to 0-5V output range
maxallow = maxallow*k2;
// map it to the range of the analog out:
outputValue = map(maxallow, 0, 1023, 0, 255);
// change the analog out value:
analogWrite(analogOutPin, outputValue);
// print the results to the serial monitor:
goTo(0);
Serial.print("Turb RPM: " );
Serial.print(turrpm);
goTo(16);
Serial.print("Wind Sped: ");
Serial.println(Count1);
// wait 10 milliseconds before the next loop
// for the analog-to-digital converter to settle
// after the last reading:
delay(10);
void Second()
for (int i = 0; i < 9; i++)
sumTurRPM = TurRPM[i+1] +sumTurRPM;
sumWindMS = WindMS[i+1] +sumWindMS;
TurRPM = TurRPM[i+1];
WindMS = WindMS[i+1];
TurRPM[9] = (Count1*15); //Gives Turbine in RPM
Count1 = 0;
turrpm = (sumTurRPM + TurRPM[9])/10;
sumTurRPM = 0;
//Gives wind in ms
WindMS[9] = (2*pi*6*(Count2*60))/(60*100); //wind M/S
Count2 = 0;
windms = (sumWindMS + WindMS[9])/10;
sumWindMS = 0;
void WindSpeed()
Count2 = Count2 +1;
void TurbineRPM()
Count1 = Count1 +1;
void goTo(int position) { //position = line 1: 0-15, line 2: 16-31, 31+ defaults back to 0
if (position<16){ Serial.print(0xFE, BYTE); //command flag
Serial.print((position+128), BYTE); //position
}else if (position<32){Serial.print(0xFE, BYTE); //command flag
Serial.print((position+48+128), BYTE); //position
} else { goTo(0); }
delay(10);
void backlightOn(){ //turns on the backlight
Serial.print(0x7C, BYTE); //command flag for backlight stuff
Serial.print(157, BYTE); //light level.
delay(10);
What is goin on? I need to use these other interrupt ports.
