Topic: LM2931-5 does not do its job... (Read 2966 times) previous topic - next topic
SadiaV
Hello,
I have a bit of a problem... For some reason LM2931AZ50R LDO voltage regulator does not regulate to 5V as it is supposed to... I'm using 12V for Vin (with approx 20mA load between Vout & GND)
Everything is connected according to the datasheet guidelines (link: http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00001885.pdf)
Without any load it gives me ~5.2V, with the load ~6.3V... And that's not good...
I though it might be  a bad regulator, so I tried another one. And the same thing. Does not work.
Any ideas?
RuggedCircuits
Gee...there's not much that can go wrong here. The only thing I can think of is you have it backwards. Did you notice the pin diagram on page 4 of the datasheet is a bottom view of the part (not looking at the part from the top)?
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
runaway_pancake
You're absolutely certain about your pin-out (Fig. 2), using the circuit in Fig. 3?
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
SadiaV
runaway_pancake: yes, I'm using the circuit from Fig.3 with capacitors as specified.
RuggedCircuits, runaway_pancake: The pinout shout be correct. (the regulator is in TO92 package), if I look at it with the leads pointing towards me and flat part to the top the pinout should be as in the Fig.2 (left pin: Vout, Gnd, right pin: Vin)? Isn't this correct?
RuggedCircuits
Sounds right...I'm stumped. Could you have 2 bad parts??? Are you sure it's the right part (look at the markings....)
Tell us more about the load, where the input voltage is coming from, etc. Can you post a picture?
The Aussie Shield: breakout all 28 pins to quick-connect terminals
James C4S
How expendable are the parts?  Maybe try reversing one to see if it is a wiring issue.  (Doesn't sound like it, but not much else to consider.)
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
Grumpy_Mike
Yes we need to see a photograph.
Mind you I wonder why you chose this part. It is a very low drop out part and you are feeding it with 12V. So you get all the stability problems associated with a low drop out part but none of the advantages.
SadiaV
Thanks for replies, I'll post the picture tomorrow when I get home. I have more of them, so I'll do some testing with  a third :)
I'm using 12 V just for testing. The device is going to be powered from some lipo batteries and I need it to work to close to 6V... Could not do it with simple voltage regulators...
SadiaV
Ok, this is the image of how I have it connected...
Tried with the third one. The same thing. I even picked up a lipo battery and tried it from it (7.5V). The same thing.. 6.3V out. Strange things are happening... I do not get it. I thought maybe my multimeter is wrong, but it isn't. Tested with two of them (MT-1820 and DVM1400) and the readings are the same.
P.S. There are 100n capacitors going from vout to GND and Vin to GND. Forgot to add them to the picture.
James C4S
Just for the record, Vo is shown as 100µF, not 100nF.
What is the load?
SadiaV
What is the load?
I've noticed that, but I hoped it had no serious influence. Isn't the purpose of the capacitors just to clean up the output?
The load for now is an LED and 470ohm resistor, so the current should be approx 4mA.
But, as mentioned before, even with no load it does not regulate properly...
SadiaV
#11
Nov 06, 2011, 05:15 am Last Edit: Nov 06, 2011, 05:25 am by SadiaV Reason: 1
Wow, lo and behold... I changed the output cap to 2.2 uF electrolytic (had some of those laying around) and guess what... 5.05V.  Thanks for help guys!
EDIT. connected the output to the scope.
Adding a larger cap reduces the ripple. Seems I need to follow the application notes more carefully.
James C4S
Your definition of "clean-up" may very well differ from the person who designed the regulator.  As mike suggested, LDOs are FAR more sensitive to oscillations.  A LDO isn't as forgiving on a demanding output-load.
You can't fault a design if you don't follow the recommended guide.
