Topic: send a byte array to arduino over serial from processing? (Read 5260 times) previous topic - next topic
jfenwick
I'm having trouble sending a byte array to an Arduino using Processing.
I'm using a modified version of the standard PhysicalPixel example.
When you mouseover the square I set the first byte to 255.
It seems to be setting it correctly.
But when it gets to the Arduino I'm having a hard time figuring out how to read the value.
I tried printing using Serial.print but it's hard to understand what it's saying.
Arduino code:
Code: [Select]
const int ledPin = 13; // the pin that the LED is attached to
int incomingByte;      // a variable to read incoming serial data into
#define MAX_MILLIS_TO_WAIT 1000  //or whatever
unsigned long starttime;
byte bytes[512];
  // initialize serial communication:
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  starttime = millis();
  while ( (Serial.available() < 512) && ((millis() - starttime) < MAX_MILLIS_TO_WAIT) ) {
  // hang in this loop until we either get 9 bytes of data or 1 second
  // has gone by
  if (Serial.available() < 512) {
    // the data didn't come in - handle that problem here
    Serial.println("ERROR - Didn't get 512 bytes of data!");
    Serial.flush();
  else {
    for(int n=0; n < 512; n++) {
      bytes[n] = Serial.read(); // Then: Get them.
    //Serial.println(bytes[0]);
    if (bytes[0] == 255) {
      digitalWrite(ledPin, HIGH);
    else {
      digitalWrite(ledPin, LOW);
Processing code:
Code: [Select]
import processing.serial.*;
float boxX;
float boxY;
int boxSize = 20;
boolean mouseOverBox = false;
Serial port;
byte[] bytes = new byte[512];
  size(200, 200);
  boxX = width/2.0;
  boxY = height/2.0;
  rectMode(RADIUS);
  // List all the available serial ports in the output pane.
  // You will need to choose the port that the Arduino board is
  // connected to from this list. The first port in the list is
  // port #0 and the third port in the list is port #2.
  println(Serial.list());
  // Open the port that the Arduino board is connected to (in this case #0)
  // Make sure to open the port at the same speed Arduino is using (9600bps)
  port = new Serial(this, Serial.list()[0], 115200);
  for (int i=0; i<512; i++) {
    bytes[i] = byte(0);
void draw()
  background(0);
  // Test if the cursor is over the box
  if (mouseX > boxX-boxSize && mouseX < boxX+boxSize &&
    mouseY > boxY-boxSize && mouseY < boxY+boxSize) {
    mouseOverBox = true;
    // draw a line around the box and change its color:
    stroke(255);
    fill(153);
    // send an 'H' to indicate mouse is over square:
    //port.write('H');
    bytes[0] = byte(255);
    //print(bytes);
    port.write(bytes);
  else {
    // return the box to it's inactive state:
    stroke(153);
    fill(153);
    // send an 'L' to turn the LED off:
    port.write('L');
  // Draw the box
  rect(boxX, boxY, boxSize, boxSize);
What am I doing wrong here?
CrossRoads
You may have to do it as smaller chunks - the incoming data buffer is not that  big.
PaulS
Since you are sending one byte from the Processing application, why are you expecting 512 bytes?
What is the Processing application eventually going to be doing?
Crossroads is right. You need to figure out a way to transfer the data in 128 byte or smaller segments.
Even of the Arduino did have a 512 byte buffer, and Processing was sending 512 bytes, it could conceivably take more than a second to send all the data. Giving up after a second, a flushing every that has arrived but not been read is a bad idea. (Giving up isn't. Flushing is.)
