Topic: Someone please check this out and tell me what can I do to perfect it. (Read 992 times) previous topic - next topic
KevinPearson
Im trying to make an obstacle avoidance robot with 2dc motors, parallax sonar sensor, and a servo to rotate 0-180deg. I somewhat have it working but it needs some tweeking. Especially on the turning part. Please help heres my code! :smiley-red:
Code: [Select]
#include <TimedAction.h>
#include <AFMotor.h>
#include <Servo.h>
// create a servo variable
Servo myservo;
//create 2 motor variable's
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
// create ping sensor variable
const int pingPin = 12;
int sensor;
// other variable's
int dist = 12;
int Left = 18;
int Right = 22;
//Start serial port at 9600 buad rate
 // what pin the servo is attached to
 myservo.attach(9);
 //set the initial speed of the motors
 motor2.setSpeed(200);
 motor3.setSpeed(200);
 //  motor control  Just telling the motors to be at rest. Note commands are ALL CAPS!
 motor2.run(FORWARD);
 motor3.run(FORWARD);
 // the first  servo position
 myservo.write(75);
 delay(300);
 // establish variables for duration of the ping,
 // and the distance result in inches and centimeters:
 long duration, cm;
 // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
 // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
 pinMode(pingPin, OUTPUT);
 digitalWrite(pingPin, LOW);
 delayMicroseconds(2);
 digitalWrite(pingPin, HIGH);
 delayMicroseconds(5);
 // The same pin is used to read the signal from the PING))): a HIGH
 // pulse whose duration is the time (in microseconds) from the sending
 // of the ping to the reception of its echo off of an object.
 pinMode(pingPin, INPUT);
 duration = pulseIn(pingPin, HIGH);
 // convert the time into a distance
 cm = microsecondsToCentimeters(duration);
// place to distance of cm into variable sensor
  sensor=cm;
  //print distance of closest object in view
 Serial.print(cm);
 Serial.print("cm");
// this next bit of code compares the sensor data to the predetermind dist set buy the user
//to decide to go forward  or to stop
 if (sensor >= dist)
   delay(250);
 if (sensor <= dist)
 {  motor2.run(RELEASE);
   motor3.run(RELEASE);
    myservo.write(20);
    delay(300);
 myservo.write(160);
   Right = cm;
     myservo.write(20);
   Left = cm;
   myservo.write(180);
   delay(100);
   if (Right <= Left)
  {  motor2.setSpeed(170);
 motor3.setSpeed(170);
   motor3.run(BACKWARD);
   delay(1);}
    if (Right >= Left)
     motor2.run(BACKWARD);
   delay(1);}
 { motor2.run(FORWARD);
   delay(10);
long microsecondsToInches(long microseconds)
 // According to Parallax's datasheet for the PING))), there are
 // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
 // second).  This gives the distance travelled by the ping, outbound
 // and return, so we divide by 2 to get the distance of the obstacle.
 // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
 return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
 // The speed of sound is 340 m/s or 29 microseconds per centimeter.
 // The ping travels out and back, so to find the distance of the
 // object we take half of the distance travelled.
 return microseconds / 29 / 2;
Moderator: Code box added.
Graynomad
Can you properly format the code by editing the post, highlighting the code and clicking the # button.
One problem might be this
Code: [Select]
myservo.write(75);
It's done at the start of every loop then further down the loop you have
Code: [Select]
  if (sensor <= dist)
     myservo.write(20);
     delay(300);
  myservo.write(160);
I didn't analyze all the code paths but that first write to the servo seems a little strange. What's the point in constantly resetting its location to 75 then changing it again to 20 or 160?
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
sLoki
I've built something similar. I did some testing and the US sensor will return range readings on any object within a 20 degree (from memory) "cone". It returns the distance to the closest object within the 20 degrees.
I've done a small amount of experimenting with focusing the range by putting cardboard around the sensor, it seemed to work okay but I need to do more testing.
If you want any help on specific issues PM and I'll help if I can :)
AWOL
This code
Code: [Select]
is repeated three times.
A simple function would shorten your code and make your sketch easier to maintain or expand.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
