Loading...
Pages: [1]   Go Down
Author Topic: i2c byte data to char  (Read 273 times)
Offline Offline
Newbie
View Profile
Hello !
How do i convert Byte (Uint8_t) comming from:
Code:
uint8_t datastring;
Wire.requestFrom(0x60,67); //Lets fetch the stuff; 67Bytes of fun.
datastring |= Wire.receive();
to a char string?
Lots of commas in between, but they are cruciel to be kept.
further on - last two bytes will be
<cr><lf>k
as far as I know char is signed in Arduino -127/+128 and datastring will be 0-255
thanks for Help !
Logged
0
Offline Offline
Full Member
Safety first.
View Profile
I'm curious to know also.
My first try would be type casting.
Does this work?
char test = (char)datastring;
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Something like this should work. I wouldn't worry about the different data types, the compiler isn't.
Code:
const int WANTED_NUMBER = 67;
uint8_t datastring [WANTED_NUMBER];
bool getData ()
  if (Wire.requestFrom (0x60, WANTED_NUMBER) < WANTED_NUMBER)
    return false;  // didn't get number we wanted
 // get each byte
  for (byte i = 0; i < WANTED_NUMBER; i++)
    datastring [i] = Wire.receive ();
  return true;  // OK
}  // end of getData
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
If you are planning to treat it as a "C" string you might add a terminating 0x00 byte:
Code:
uint8_t datastring [WANTED_NUMBER + 1];
bool getData ()
  if (Wire.requestFrom(0x60, WANTED_NUMBER) < WANTED_NUMBER)
 // get each byte
  datastring [WANTED_NUMBER] = 0x00;  // terminating null
  return true;  // OK
Logged
Offline Offline
Newbie
View Profile
Thanks, that worked !!
Logged
Pages: [1]   Go Up
Print
Jump to:
