Loading...
Pages: [1]   Go Down
Author Topic: Convert int to binary Array  (Read 1100 times)
Offline Offline
Jr. Member
View Profile
Hi!
Is there an easy way (or function) to convert a integer ( 1 to 128) to an 7bit Binary code array?
I found the following function String(myInt,BIN) which works (tried it with the Serial.println() function). But how can i put this into a String (or better a string array)?
The next thing is to write the String to the digital Out Pins ( Pin 13 to 19). This can easily be done with a for loop.
So, how do I convert my integer to an Array?
regards
tsaG
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
bitRead
Please, don't use String
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Edison Member
Arduino rocks
View Profile
Check out the bitRead function:
Code:
const byte numPins = 7;
byte pins[] = {13, 14, 15, 16, 17, 18, 19};
  while(!Serial.available()); // Do nothing until serial input is received
  byte num = Serial.read(); // Get num from somewhere
  for (byte i=0; i<numPins; i++) {
    byte state = bitRead(num, i);
    digitalWrite(pins[i], state);
    Serial.print(state);
Logged
Offline Offline
Jr. Member
View Profile
Thank you! exactly what I was looking for.
Logged
Leeds, UK
Offline Offline
God Member
Once the magic blue smoke is released, it won't go back in!
View Profile
WWW
Arduino has an implementation of itoa() which can also be used for this purpose
Just a quick example
Code:
  for(byte i = 0; i < 7; i++){
    pinMode(i+13,OUTPUT);
  byte someValue = 20; //For this example, lets convert the number 20
  char binary[9] = {0}; //This is where the binary representation will be stored
  someValue += 128; //Adding 128 so that there will always be 8 digits in the string
  itoa(someValue,binary,2); //Conver someValue to a string using base 2 and save it in the array named binary
  char* string = binary + 1; //get rid of the most significant digit as you only want 7 bits
  Serial.println(string); //print out our string.
    digitalWrite(i+13,string[i] - '0'); //write to the pin (the - '0' converts the bit of the string to HIGH or LOW)
Logged
~Tom~
Offline Offline
Jr. Member
View Profile
Okay, everything works properly. the next problem is to get the command over I2C from the master.
Code:
void receiveEvent(int howmany){
string receivestr = wire.receive() //Whole String
byte comand =bitRead(colcount, 0);
if (comand = 0){
//cut off the comand number and do this
else if (comand = 1){
Just my way of thoughts
So,
1. how do I receive the whole data. Which is the best type to put it in? I guess its not String.
2. How do I cut off the first value ( just 0 to 9) of the received data?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
OK, that kind-of assumes we all know what the Hell it is you're talking about.
Code:
Don't know of any datatypes called "string (and a missing semicolon)
Code:
if (comand = 0){
I'm betting you didn't mean an assignment.
Logged
Pages: [1]   Go Up
Print
Jump to:
