Pages: [1] 2   Go Down
Author Topic: My electrical power meter  (Read 3794 times)
Sweden
I'm so proud!
My first Arduino project is a power meter for my house.
The power meter that the electric company reads every month and sends me a bill from just states how much power is used since it started. It also sends out a light pulse for every thousands of a kWh used. I use a light dependant resistor to read the pulse and count them and the time between the pulses to get power used since my Aruino started and the current power usage. All this is displayed on a LCD shield. With the buttons on the shield i can display different things:
The total power used since the start and current usage.
Power used last minute and mean power last minute.
Power used last hour and mean power last hour.
Power used last day and mean power last day.
Power used last week and mean power last week.
Power used last four weeks and mean power four.
The sketch saves the current usage value every ten seconds and calculates everything. The values are cyclic so last days measyre ment is rather last 24h values and so on. If the Arduino is juststarted it sets a "c" in front of the values that are not correct yet (it takes four weeks to get all values correct).
The power meter, fuses and what not. And my Arduino with LCD shield.
http://imgur.com/Ub3hh.jpg
Close up of the Arduino and shield running showing the default screen: The total power used since the start and current usage .
http://imgur.com/rEISz.jpg
Code doesnt fit. It's too big. How do I do?
It was kind of an anti climax when all was in place and running. What do do now? I have an idea of another shield that kan show graphics so i can draw a graph of power usage. Connecting a memory card so I can import the readings to my computer and analyze the readings more. And... And... Is there evera finished product?
/Ulf
Sweden
And the code part one:
#include <LCD4Bit_mod.h>  //Acess to LCD library
#include <stdio.h>  //Needed for sprintf conversion from long to char *
#include <string.h> //Needed for getting string lengths
LCD4Bit_mod lcd = LCD4Bit_mod(2);  //Set LCD as two line display
unsigned int timecounternow;  //Timecounters for checking if ten seconds have passed
unsigned int timecounterthen=0;
volatile unsigned long powercounternow;  //Counts time between pulses in milliseconds
volatile unsigned long powercounterlasttime=0;
byte clocksec, clockmin, clockhour, clockday, clockweek; // to keep track of time
volatile byte sensorstate = LOW;  //Start with sensor in LOW
volatile unsigned long sensortickcounter=0;  //Counts powerpulses
volatile unsigned int powerrating=0;  //Last powermeasurement
unsigned int lastsecondsticks=0; //Last minutes power usage (blinks seen last ten seconds)
unsigned long lastsecondstickscounter=0; //Counter to store time we read last ten seconds power usage
char msgs[5][17]={
  " Senaste minuten", "  Senaste timmen", "  Senaste dygnet", "  Senaste veckan", "Senaste 4 veckor"}; // Array with messages that can be displayed
int  adc_key_val[5]={
  30, 150, 360, 535, 760};  //Array for button readings
int NUM_KEYS=5;  //Number of keys available
int adc_key_in;  //To read key with
int key=-1;  // Key pressed right now, -1 if no key pressed or faulty reading
int seconds[6];  //Array that holds each powerreading done during the last minute
int minutes[60];  //Array that holds each powerusage reading done during the last hour
int hours[24];  //Array that holds each powerusage reading done during the last day
unsigned long days[7];  //Array that holds each powerusage reading done during the last week
unsigned long weeks[4];  //Array that holds each powerusage reading done during the last four weeks
unsigned int secondsvalue=0;  //Powerusage during the last minute
unsigned long minutesvalue=0;  //Powerusage during the last hour
unsigned long hoursvalue=0;  //Powerusage during the last day
unsigned long daysvalue=0;  //Powerusage during the last week
unsigned long weeksvalue=0;  //Powerusage during the last four weeks
unsigned int secondsrating[6];  //Array that holds each powerrating reading done during the last minute
unsigned long secondspowerrating=0;  //Powerrating during the last minute
char powervalue[6];  //Char array to hold power value for printing on LCD
char value[6];  //Char array to hold power usage for printing on LCD
byte a,b;  //Used to get length from strings
byte minutehaspassed=false;  //Flag to see if one minute or more has passed since start, set to false from start
byte hourhaspassed=false;  //Flag to see if one hour or more has passed since start, set to false from start
byte dayhaspassed=false;  //Flag to see if one day or more has passed since start, set to false from start
byte weekhaspassed=false;  //Flag to see if one week or more has passed since start, set to false from start
byte weekshaspassed=false;  //Flag to see if four weeks or more has passed since start, set to false from start
byte timingflag=false;  //Flag that switches between 0 and 10. Used to get tome to be more accurate
  attachInterrupt(1, sensortick, RISING);  //Set upp interrupt with sensor. If we detect a change from LOW to HIGH we call sensortick
  timecounterthen=millis();  //Arduino is running, start timing now.
  clocksec=0;  //Clock is 0:0:0:0:0 (w:d:h:m:s)when started
  clockmin=0;
  clockhour=0;
  clockday=0;
  clockweek=0;
  lcd.init();  //Initialize LCD
  lcd.clear();  //Clear LCD
  for (int i=1; i<6 ;i++)  //Each array that holds powerusage is set to contain 0 in every place
    seconds[i]=0;
  for (int i=0; i<60 ;i++)
    minutes[i]=0;
  for (int i=0; i<24 ;i++)
    hours[i]=0;
  for (int i=0; i<7 ;i++)
    days[i]=0;
  for (int i=0; i<4 ;i++)
    weeks[i]=0;
  for (int i=0; i<6 ;i++)  //Array that holds powerrating is set to contain 0 in every place
    secondsrating[i]=0;
  seconds[0]=powerrating;  //We have started so set the first seconds powerrating
  //  Serial.begin(9600);
Sweden
Code part two:
  char result[17]="                ";  //The empty string that all printing is fed to
  timecounternow=millis();  //Read clock
  if ((timecounternow-timecounterthen)>=(9918+(timingflag*6))) //Has 10 seconds passed since last clock reading? (9915 is too little and 9916 is too much...)
    updateclock();  //Update clock
      lastsecondsticks=sensortickcounter-lastsecondstickscounter;  //Update last ten seconds pulse counter
    lastsecondstickscounter=sensortickcounter;
    secondsvalue=secondsvalue-seconds[clocksec]+lastsecondsticks;  //Last minutes powerusage is updated
    seconds[clocksec]=lastsecondsticks;  //The array with last minutes powerusage is updated
    secondspowerrating=secondspowerrating-secondsrating[clocksec]+powerrating/6;  //Last minutes powerrating is updated
    secondsrating[clocksec]=(powerrating/6);  //The array with last minutes powerrating is updated
    minutesvalue=minutesvalue-minutes[clockmin]+secondsvalue;  //Last hours powerusage is updated
    minutes[clockmin]=secondsvalue;  //The array with last hours powerusage is updated
    hoursvalue=hoursvalue-hours[clockhour]+minutesvalue;  //Last days powerusage is updated
    hours[clockhour]=minutesvalue;  //The array with last days powerusage is updated
    daysvalue=daysvalue-days[clockday]+hoursvalue;  //Last weeks powerusage is updated
    days[clockday]=hoursvalue;  //The array with last weeks powerusage is updated
    weeksvalue=weeksvalue-weeks[clockweek]+daysvalue;  //Last four weeks powerusage is updated
    weeks[clockweek]=daysvalue;  //The array with last four weeks powerusage is updated
  adc_key_in=analogRead(0);  //Read value to see if a button is pressed
  key=get_key(adc_key_in);  //Convert reading to a button number
  if (key == -1)  //No button is pressed, display total usage and current rating
    sprintf(value, "%u", sensortickcounter/1000); //Convert powerusage value to string
    b=strlen(value);  //Get length of string containing powerusage
    for (int i=0; i<b; i++)  // Write powerusage to the output string
      result[i]=value[i];
    if(sensortickcounter<1000000)
      result[b]=',';
      result[b+1]=((sensortickcounter%1000)/100)+48;  //Get first decimal
    if(sensortickcounter<100000)
      result[b+2]=((sensortickcounter%100)/10)+48;  //Get second decimal
    if(sensortickcounter<10000)
      result[b+3]=(sensortickcounter%10)+48;  //Get third decimal
    result[5]='k';  //Add kWh to the output string
    result[6]='W';
    result[7]='h';
//    result[b+8]=48+clocksec;  //Print what "10 second" we are at right now. Only for testing
    sprintf(powervalue, "%d", powerrating); //Convert long powerrating to string
    a=strlen(powervalue);  //Get length of string containing powerrating
    for (int i=1; i<=a; i++)  // Write powerrating to the output string
      result[15-i]=powervalue[a-i];
    result[15]='W';  //Add W to the output string
    lcd.cursorTo(1, 0);  //Go to start of line one
    lcd.printIn("Totalt   Just nu");
    lcd.cursorTo(2, 0);  //Set cursor at start of line two
    lcd.printIn(result);  //Print powerusage and powerrating on LCD
  if (key == 0)  //Button corresponding to minutes is pressed, display last minutes usage and rating
    if(minutehaspassed)
      sprintf(value, "%d", secondsvalue); //Convert powerusage to string
      sprintf(value, "%d", sensortickcounter); //Convert powerusage to string
      result[i]=value[i];  //Add Wh to the output string
    result[b]='W';
    result[b+1]='h';
    result[b+3]=48+(clockmin/10);  //Print what minute we are at right now. Only for testing
    result[b+4]=48+(clockmin%10);
    if(minutehaspassed)
      sprintf(powervalue, "%u", secondspowerrating); //Convert long powerusage to string
      sprintf(powervalue, "%u", ((secondsvalue*360)/(clocksec)));  //Less than on hour has passed so minutesvalue is too small
    a=strlen(powervalue);  //Get length of string containing powerusage
    for (int i=1; i<=a; i++)  // Write powerusage to the output string
      result[15-i]=powervalue[a-i];  //Add W to the output string
    result[15]='W';
    lcd.printIn(msgs[0]);
  if (key == 1)       //Button corresponding to hours is pressed, display last hours usage and rating. Works the same as for minutes
    if(hourhaspassed)
      sprintf(value, "%d", minutesvalue/1000);
      b=strlen(value);
      for(int i=0; i<b; i++)
        result[i]=value[i];
      if(minutesvalue<1000000)
        result[b]=',';
        result[b+1]=((minutesvalue%1000)/100)+48;  //Get first decimal
      if(minutesvalue<100000)
        result[b+2]=((minutesvalue%100)/10)+48;  //Get second decimal
      if(minutesvalue<10000)
        result[b+3]=(minutesvalue%10)+48;  //Get third decimal
      sprintf(value, "%d", sensortickcounter/1000); //Convert powerusage to string
      b=strlen(value);
        result[i]=value[i];
        result[b]=',';
    result[5]='k';
    result[6]='W';
    result[7]='h';
//    result[b+8]=clockhour+65;  //Only for testing
    if(hourhaspassed)
      sprintf(powervalue, "%u", minutesvalue);  //More than one hour since the start has passed so minutesvalue is ok
      sprintf(powervalue, "%u", ((minutesvalue*60)/(clockmin+1)));  //Less than on hour has passed so minutesvalue is too small
      result[14-strlen(powervalue)]='c';
    for(int i=1; i<=a; i++)
    result[15]='W';
    lcd.cursorTo(1, 0);
    lcd.printIn(msgs[1]);
    lcd.cursorTo(2, 0);
  if (key == 2)       //Button corresponding to days is pressed, display last days usage and rating. Works the same as for minutes
    if(dayhaspassed)
      sprintf(value, "%d", hoursvalue/1000);
      b=strlen(value);
        result[i]=value[i];
      if(hoursvalue<1000000)
        result[b]=',';
        result[b+1]=((hoursvalue%1000)/100)+48;  //Get first decimal
      if(hoursvalue<100000)
        result[b+2]=((hoursvalue%100)/10)+48;  //Get second decimal
      if(hoursvalue<10000)
        result[b+3]=(hoursvalue%10)+48;  //Get third decimal
      b=strlen(value);
        result[i]=value[i];
        result[b]=',';
    result[5]='k';
    result[6]='W';
    result[7]='h';
//    result[b+8]=48+clockday;  //Only for testing
    if(dayhaspassed)
      sprintf(powervalue, "%u", (hoursvalue/24));  //More than one day since the start has passed so hoursvalue is ok
      sprintf(powervalue, "%u", ((hoursvalue*60)/(clockhour*60+clockmin+1)));  //Less than on day has passed so hoursvalue is too small
    result[15]='W';
    lcd.cursorTo(1, 0);
    lcd.printIn(msgs[2]);
    lcd.cursorTo(2, 0);
Sweden
Code part three (last part):
 if (key == 3)       //Button corresponding to weeks is pressed, display last weeks usage and rating. Works the same as for minutes
    if(weekhaspassed)
      sprintf(value, "%u", daysvalue/1000);
      b=strlen(value);
        result[i]=value[i];
      if(daysvalue<1000000)
        result[b]=',';
        result[b+1]=((daysvalue%1000)/100)+48;  //Get first decimal
      if(daysvalue<100000)
        result[b+2]=((daysvalue%100)/10)+48;  //Get second decimal
      if(daysvalue<10000)
        result[b+3]=(daysvalue%10)+48;  //Get third decimal
      b=strlen(value);
        result[i]=value[i];
        result[b]=',';
    result[5]='k';
    result[6]='W';
    result[7]='h';
//    result[b+8]=48+clockweek;  //Only for testing
    if(weekhaspassed)
      sprintf(powervalue, "%u", (daysvalue/(24*7)));  //More than week hour since the start has passed so daysvalue is ok
      sprintf(powervalue, "%u", ((daysvalue*60)/(clockday*24*60+clockhour*60+clockmin+1)));  //Less than on week has passed so daysvalue is too small
    result[15]='W';
    lcd.cursorTo(1, 0);
    lcd.printIn(msgs[3]);
    lcd.cursorTo(2, 0);
  if (key == 4)       //Button corresponding to four weeks is pressed, display last four weeks usage and rating. Works the same as for minutes
    if(weekshaspassed)
      sprintf(value, "%u", weeksvalue/1000);
      b=strlen(value);
        result[i]=value[i];
      if(weeksvalue<1000000)
        result[b]=',';
        result[b+1]=((weeksvalue%1000)/100)+48;  //Get first decimal
      if(weeksvalue<100000)
        result[b+2]=((weeksvalue%100)/10)+48;  //Get second decimal
      if(weeksvalue<10000)
        result[b+3]=(weeksvalue%10)+48;  //Get third decimal
      b=strlen(value);
        result[i]=value[i];
        result[b]=',';
    result[5]='k';
    result[6]='W';
    result[7]='h';
    if(weekshaspassed)
      sprintf(powervalue, "%u", (weeksvalue/(24*7*4)));  //More than four weeks since the start has passed so weeksvalue is ok
      sprintf(powervalue, "%u", ((weeksvalue*60)/(clockweek*7*24*60+clockday*24*60+clockhour*60+clockmin+1)));  //Less than four weeks has passed so weeksvalue is too small
    result[15]='W';
    lcd.cursorTo(1, 0);
    lcd.printIn(msgs[4]);
    lcd.cursorTo(2, 0);
  timingflag= !timingflag;  //Change flag for next run in the loop
int get_key(unsigned int input)  //Converting input reading to corresponding button number (1-5), return -1 if no button pressed
  int k;
  for (k=0; k<NUM_KEYS; k++)
    if (input < adc_key_val[k])
      return(k);
  if (k >= NUM_KEYS)
    k=-1;     // No key pressed or an error occurred
  return(k);
void updateclock()  //Updating clock 0:0:0:0:0 -> 0:0:0:0:1 and so on
  timecounterthen=timecounternow;  //Reset time counter
  if (clocksec>=5)  //if more than 50 (seconds are only stored as 0-5) seconds have passed seconds are set to 0
    clocksec=0;
    minutehaspassed=true;  //One minute has passed since the start so set flag true
    if( clockmin>=59)  //if more than 59 minutes have passed minutes are set to 0
      clockmin=0;
      hourhaspassed=true;  // One hour has passed since the start so set flag true
      if(clockhour>=23)  //if more than 23 hours have passed hours are set to 0
        clockhour=0;
        dayhaspassed=true;  // One day has passed since the start so set flag true
        if (clockday>=6)  //if more than 6 days have passed days are set to 0
          clockday=0;
          weekhaspassed=true;  // One week has passed since the start so set flag true
          if(clockweek>=3)  //if more than 3 veeks have passed weeks are set to 0
            clockweek=0;
            weekshaspassed=true;  // Four week has passed since the start so set flag true
          else clockweek=clockweek+1;  //Less than 4 weeks have passed so update weeks by one
          clockday=clockday+1;  //Less than 7 days have passed so update days by one
        clockhour=clockhour+1;  //Less than 24 hours have passed so update hours by one
      clockmin=clockmin+1;   //Less than 60 minutes have passed so update minutes by one
    clocksec=clocksec+1;   //Less than 60 days have passed so update seconds by ten
void sensortick() //The interrupt routine
  powercounternow=micros();  //At what time did we se the pulse?
  //Serial.println(powercounternow-powercounterlasttime);
  sensortickcounter=sensortickcounter+1;  //Update number of pulses seen
  powerrating=3600000000/(powercounternow-powercounterlasttime);  //Calculate length of pulse and update current powerrating
  powercounterlasttime=powercounternow;  //Last time we saw a pulse was now
  sensorstate = LOW;
Nicely done. Thanks for posting pictures and code (and comments in English smiley).
Austria
looks nice smiley
can you describe the pickup from the meter a little more?
Sweden
Thanks for the positive feedback, in makes me even more proud.
I learned the hard way to comment code when I studied. A professor told me to comment the some code two weeks after I wrote it. It took me four times the time to comment it than to write the code.
The light resistor is connected to 5v and pin 3 and. And there is a 4 Mohm something resistor connected to pin 3 and ground. So if the light resistor sees darkness pin 3 is connected to ground and if it sees light pin 3 is connected to 5v. That vay i can read changes from LOW to HIGH on pin 3.
Copenhagen / Denmark
Do it !
Really cool project, i guess my meter is the same type. Unfortunately it is in a little box on the outside of my house.
Your next project ?
As a friend of mine always says:
Your project isn't finished before you build the box for it :-)
Sweden
Your friend is right. I was looking for a box to make it more finished but instead i screwed i on the wall so it feels pretty finished.
Next project could be to add a thermometer to see how the power usage is correlated to outside temperature. Add some memory and a real time clock to see when the most power is used.
But instead I've started a project to measure the speed of cars passing by on the street.
tytower
Guest
Add a radio transmitter and send it to your pc . Receiver on that end . Total cost  $20 plus an arduino on the pc end
see here
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1256188633/60#60
« Last Edit: November 24, 2009, 07:51:55 pm by tytower » Logged
Sweden
Not a bad idea! Will look into it. Thanks for the idea.
/Ulf
Hi Ulf,
that's great project - the one what I searched for.
could you please give me some idea how to connect photoresistor to arduino? some sketch should be great.
I want to read power usage from 3 electric meters - one heating system, one water heating system and air exchanger system.
thanks in advance
Maciek
Sweden
Sure, here comes a schematic:
Great project
Nice project smiley
I've always wanted to know exactly how much energy I'm using, and now I'm just days away to get my own solution working smiley
I do not have any experience in Arduinos, but I plan to use an ATmega(8,16,32), I'm not sure what will suit my application best. Those computers do have UART interface and that is good news since the old laptop I uses as home webserver has a RS232 (serial) interface. The plan is to buffer the meter reading in the ATmega and send to laptop (server) and perhaps use another ATmega coupled with a DS1620 digitalthermometer. And then correlate used energy with outdoor temperature smiley
Python and pySerial is quite easy to use when interfacing with UART.
I tried various solutions before ordering some ATmega.
The first try were 6-7 years when I studied, my apartment had the meter in my office/study, and I used my (only) optical mouse and taped it to the meter with the optical sensor right above the light, and were able to make a Java program that registered changing states in the serial transfer. It was a bad solution since I were a student and a new mouse would cost too much.
Just recently I tried to use a photoresistor and photodiode with a parallel port to do the same trick, but i was not able to get any stable signal through.
Mmmh, should perhaps have something measuring the take wind speed also...
Pages: [1] 2   Go Up
