Topic: WaveHC Play one file after the other (Read 1 time) previous topic - next topic
hintswen
I have this: http://www.emartee.com/product/41973/
I want to play some audio files one after the other by specifying the file name and path.
Anyone know how? The example has just confused me so much >.<
Grumpy_Mike
So do you have an SD card interface on your arduino, you need one. You need to put several WAV files on it.
You then have a list of file names to play in your arduino sketch.
You use these one at a time to open the file and transfer the file byte by byte to your card.
Then at the end of the file you need to close it and open the next one in the list.
It's not easy.
hintswen
I have what I linked to (and the other parts in the picture further down on the page). SO yes I have an SD Card, I'm just looking for the code to queue files to play, or even just code where I can play a file with a specific name. The example code on that page just doesn't make sense to me. I was hoping someone would already have some code I can look at.
Grumpy_Mike
Quote
In what way? Does it work for you?
It loads and compiles on the arduino and just plays every file it sees on the SD card.
If you want to hack that to only play files on your list then it is the void play(FatReader &dir) function you want to change.
The simplest way would probably be to include a check to see if the file it is going to play is the next on your list, if not you keep looking.
hintswen
I found some more example code which included a function to play a file by specifying the file name. Now that I have that code I am looking to use an array to store the file names of the next few sounds then make it check the array to see if there are any sounds that need to be played.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
