Topic: Visual Basic 2008 & Arduino Uno (Read 2210 times) previous topic - next topic
Shrykull
Hey guys,
I would like your help in this, perhaps small matter, please.  :)
Beforehand I say that I'm not an advanced programmer in both these languages, that's why I'm posting here.
I'm trying to send some values through the interface I've created in VB2008 to the Arduino.
First off, I seem to don't be able to use the serial scope on Arduino when I have an open connection between VB2008 and Arduino which is very inconvenient, is that normal? Is there any practical way around this?
And second, then I want to send some values let's say 70 20 0.6. So VB2008 will send them all in a row and the problem on the receiver's side (Arduino) is that using the following code:
int incomingByte = 0;   // for incoming serial data
   Serial.begin(9600);   // opens serial port, sets data rate to 9600 bps
   // send data only when you receive data:
   if (Serial.available() > 0) {
      // read the incoming byte:
      incomingByte = Serial.read();
      // say what you got:
      Serial.print("I received: ");
      Serial.println(incomingByte, DEC);
it saves every number to a variable therefore separating the values I want.
So the approach I take next is to send each value terminated with a character, lets say '-'. Now, on the receiver's side I try to collect the numbers I'm receiving in a string until I get the '-'. And this is working. So finally, the problem is being to store these strings with the value I want in an int or a float variable.
Can you give me some advice, please? And also if there is a much better way to solve this, please let me know.  :)
Thanks
PaulS
Quote
Yes, it is. Only one application can listen to a serial port at a time.
Quote
No. And there really doesn't need to be. You can get the Arduino working, writing to it using the Serial Monitor, and seeing its responses. When the Arduino works, you make the VB app send the same data you were typing in the Serial Monitor, and read the returned data. Since you have a known output format, and known responses (the same ones you saw in the serial monitor) this should be relatively easy.
Quote
<snip>
To be pedantic, it saves every character to the same variable. The "separation" you speak of occurs in the output stream.
Quote
Not with that code you don't.
Quote
Not with that code.
Quote
How to parse the string, and convert the values to numbers so that they can be stored in variables depends on how you are collecting the data.
Post that code for real help.
The indexOf() and substring and toInt() functions look useful, if you are using String.
The strtok() and atoi() and atof() functions are useful if you are doing it right and using a NULL terminated char array.
Shrykull
Thank you for the prompt reply PaulS.
Well the code I showed was the one I used to develop upon. What I have so far is something like this:
byte data = 0;   // for incoming serial data
float a = 0;
float b = 0;
float c = 0;
int count = 0;
String value = '\n';
      data = Serial.read();
      Serial.println(data);
                if(data != '-'){
                  value += data;
                else{
                  count++;
                  if(count == 1) a = float(value);
                  if(count == 2) b = float(value);
                  if(count == 3){
                    c = float(value);
                    count = 0;
                    //Serial.print("value = ");Serial.println(value);  //for testing
                    Serial.print("a = ");Serial.println(a);
                    Serial.print("b = ");Serial.println(b);
                    Serial.print("c = ");Serial.println(c);
The 'float(value)' are of course failing.
PaulS
Quote
Well, of course they are. The float macro is a crutch for people that don't understand casts. It evaluates to
Code: [Select]
    if(count == 1) a = (float)value;
which, of course, is nonsense, since a String object can not be cast to a float.
You could use the value.toCharArray() method to extract the char array from the String object, then use atof() on the char array.
Shrykull
OK, thanks for the help PaulS. I'm going to try it out.
Is this the way used to receive values with more than one digit? Or is there another practical, more used, way to deal with these situations?
PaulS
Quote
No.
Quote
Collect the data received, up to an end-of-packet marker, in an array. Deal with the contents of the array when the end-of-packet marker arrives.
http://jhaskellsblog.blogspot.com/2011/05/serial-comm-fundamentals-on-arduino.html
