Topic: 315Mhz receiver - four pins? (Read 7813 times) previous topic - next topic
CowJam
Nov 09, 2011, 09:57 pm Last Edit: Nov 09, 2011, 09:59 pm by CowJam Reason: 1
Ages ago I picked up a 315Mhz transmitter (KXDJS2002.1) and receiver - these ones: http://www.geeetech.com/index.php?main_page=product_info&cPath=23&products_id=74
I can't remember where I got them and I can't find anywhere that says what the pins are on the receiver (the transmitter pins are labelled).
All the tutorials about these things have more pins on the receiver.
Any ideas on what the pins are likely to be (and if I'm likely to break it by putting the 5v on the wrong pin)?
EDIT: Never mind, it's in one of the pictures on the link above.  Rather than deleting this I'll leave it here in case anyone's googling for the same thing later.
It's GND, Dat1, Dat2 and Vcc starting from the nearest edge.
CrossRoads
Isn't one of those pins the Antenna in?
CowJam
Don't know. I've got it working using dat1 and the built-in antenna.
smartgatto
#3
Dec 22, 2011, 06:27 pm Last Edit: Dec 22, 2011, 06:49 pm by smartgatto Reason: 1
hi, I have the same transmitter, but the 433Mhz one. I have the same problem, and thank you for your "edit" :-)
but i don't understand if pin near the corner is Vcc or GND. Thank you!
I have the receiver (KXD10036) too but I don't know pins  =(
EDIT:
i found it!
