Topic: Infrared - Sharp 2D120X problem please help me (Read 2201 times) previous topic - next topic
seaseasea
Hello, I am so frustrated on trying to make this thing work. I'm Newbie! Please correct me.
there are 3 color of wire, red wire to 5v, yellow to A1 (analog), black to ground.
I got this as the result:
100
6
45
108
123
37
0
0
15
79
128
104
8
0
Code: [Select]
//Reads and analog sensor and displays the value
int sensePin = 7;
  //Note: We don't need to specifiy sensePin as an
  //input, since it defaults to that when we read it
  //This is the default value, but we can set it anyways
  analogReference(DEFAULT); //5V Reference on UNO
  //Allows us to listen to serial communications from the arduino
  // print the button state to a serial terminal
  Serial.println(analogRead(A1));
  //wait half a second, then print again.
Grumpy_Mike
Looks like you haven't wired it up correctly. Is the ground connected? Is the power connected to the sensor?
For best help provide a link to the sensor's data sheet.
seaseasea
There is 3 wire, black on the left, red in the middle, yellow on the right. black connect to Ground, red to 5v., yellow to A0.
Grumpy_Mike
The data sheet says to connect a 47uF capacitor across the supply as close to the sensor as you can get. Try that.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
