Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #15 on: November 13, 2011, 11:58:04 am » |
The SetText() method in my code is how the serial read thread communicates with the user interface thread.
Get rid of all the stuff you are doing in Read() (with the data read from the serial port). Move that code to the SetText() method (in the else block).
The new data for the graph will then be available for you to use. If all you want is the x, y values, there is no reason to store all 7 values in an array.
Logged
Offline
Sr. Member
« Reply #16 on: November 13, 2011, 12:15:14 pm » |
i will eventually use all 7 values jsut not yet; i have to get it to work first  ok after i move the splitting code, do i still sue message as the string to split? or "text" ?
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #17 on: November 13, 2011, 12:19:26 pm » |
In the SetText function, the data is pointed to by text.
Logged
Offline
Sr. Member
« Reply #18 on: November 13, 2011, 12:21:14 pm » |
im confused.
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #19 on: November 13, 2011, 12:28:13 pm » |
When you call SetText(), you pass it some data, through its argument list. The data you are passing it is a string, referred to by the name message.
In the SetText() function, that same data is referred to as text. If you want to continue to refer to it as message, change the variable name in the function declaration.
Logged
Offline
Sr. Member
« Reply #20 on: November 13, 2011, 01:16:40 pm » |
if text is the correct string for splitting, why: Input string was not in a correct format exception?
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #21 on: November 13, 2011, 01:27:09 pm » |
Please post the specific message you are seeing. Please post the code you have (at least the SetText() function).
Adding a Console.WriteLine() statement to output what is in text might provide a clue.
Logged
Offline
Sr. Member
« Reply #22 on: November 13, 2011, 02:07:13 pm » |
private void SetText(string text) { // InvokeRequired required compares the thread ID of the // calling thread to the thread ID of the creating thread. // If these threads are different, it returns true. if (this.receiveText.InvokeRequired) { SetTextCallback d = new SetTextCallback(SetText); this.Invoke(d, new object[] { text }); } else { this.receiveText.Text += text; this.receiveText.Text += "\n";
//Handle data recieved; something like: 1023,1023,1023,1,1,1,1, string[] split = text.Split(new Char[] { ',' });
int cntwrite = 0; foreach (string s in split) { if (s.Trim() != "") { int c = Int32.Parse(s); JoyData[cntwrite] = c; //adds each new value split(s) from SerRead string to JoyData array ++cntwrite; if (cntwrite > 6) //reset cntwrite for next time serial data is recieved { cntwrite = 0; } } } this.SetText("X:"); this.SetText(JoyData[0].ToString() + Environment.NewLine); this.SetText("Y:"); this.SetText(JoyData[1].ToString() + Environment.NewLine); this.SetText("S:"); this.SetText(JoyData[2].ToString() + Environment.NewLine); this.SetText(Environment.NewLine); } if i take out the splitting code, it works fine
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #23 on: November 13, 2011, 02:18:51 pm » |
this.SetText("X:"); this.SetText(JoyData[0].ToString() + Environment.NewLine); this.SetText("Y:"); this.SetText(JoyData[1].ToString() + Environment.NewLine); this.SetText("S:"); this.SetText(JoyData[2].ToString() + Environment.NewLine); this.SetText(Environment.NewLine); There is no reason to call the SetText() function from the user interface thread. this.receiveText.Text += "X: "; this.receiveText.Text += JoyData[0].ToString(); this.receiveText.Text += "\n"; this.receiveText.Text += "Y: "; this.receiveText.Text += JoyData[1].ToString(); this.receiveText.Text += "\n"; this.receiveText.Text += "S: "; this.receiveText.Text += JoyData[2].ToString(); this.receiveText.Text += "\n";
Logged
Offline
Sr. Member
« Reply #24 on: November 13, 2011, 02:31:08 pm » |
it was just there a debugger; it doesn't make a difference with the error
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #25 on: November 13, 2011, 03:39:22 pm » |
it doesn't make a difference with the error It did for me. private void SetText(string text) { // InvokeRequired required compares the thread ID of the // calling thread to the thread ID of the creating thread. // If these threads are different, it returns true. if (this.receiveText.InvokeRequired) { SetTextCallback d = new SetTextCallback(SetText); this.Invoke(d, new object[] { text }); } else { this.receiveText.Text += "Text: "; this.receiveText.Text += text; this.receiveText.Text += Environment.NewLine;
//Handle data recieved; something like: // 1023,1023,1023,1,1,1,1, string[] split = text.Split(new Char[] { ',' });
int[] JoyData = new int[7]; int cntwrite = 0; foreach (string s in split) { if (s.Trim() != "") { int c = Int32.Parse(s); JoyData[cntwrite] = c; ++cntwrite; if (cntwrite > 6) { cntwrite = 0; } } }
this.receiveText.Text += "X: "; this.receiveText.Text += JoyData[0].ToString(); this.receiveText.Text += Environment.NewLine; this.receiveText.Text += "Y: "; this.receiveText.Text += JoyData[1].ToString(); this.receiveText.Text += Environment.NewLine; this.receiveText.Text += "S: "; this.receiveText.Text += JoyData[2].ToString(); this.receiveText.Text += Environment.NewLine; } } Worked fine for me.
Logged
Offline
Sr. Member
« Reply #26 on: November 13, 2011, 04:25:45 pm » |
ok awesome, but the graph still doesnt update. i moved the graph under SetText and now it updates the dot the first time a serial command is received and split, but the second time serial data is received it doesn't change the dot: namespace CommunicateWithArduino { public partial class Form1 : Form { public static System.IO.Ports.SerialPort port; delegate void SetTextCallback(string text);
// This BackgroundWorker is used to demonstrate the // preferred way of performing asynchronous operations. private BackgroundWorker hardWorker;
private Thread readThread = null;
public Form1() { InitializeComponent(); hardWorker = new BackgroundWorker(); }
private void btnConnect_Click(object sender, EventArgs e) { System.ComponentModel.IContainer components = new System.ComponentModel.Container(); port = new System.IO.Ports.SerialPort(components); port.PortName = comPort.SelectedItem.ToString(); port.BaudRate = Int32.Parse(baudRate.SelectedItem.ToString()); port.DtrEnable = true; port.ReadTimeout = 5000; port.WriteTimeout = 500; port.Open();
readThread = new Thread(new ThreadStart(this.Read)); readThread.Start(); this.hardWorker.RunWorkerAsync();
btnConnect.Text = "<Connected>";
btnConnect.Enabled = false; comPort.Enabled = false; sendBtn.Enabled = true;
private void Form1_Load(object sender, EventArgs e) { foreach (string s in SerialPort.GetPortNames()) { comPort.Items.Add(s); } comPort.SelectedIndex = 0;
baudRate.Items.Add("2400"); baudRate.Items.Add("4800"); baudRate.Items.Add("9600"); baudRate.Items.Add("14400"); baudRate.Items.Add("19200"); baudRate.Items.Add("28800"); baudRate.Items.Add("38400"); baudRate.Items.Add("57600"); baudRate.Items.Add("115200");
baudRate.SelectedIndex = 2; }
private void sendBtn_Click(object sender, EventArgs e) { if (port.IsOpen) { port.Write(sendText.Text); } }
int cntwrite = 0; foreach (string s in split) { if (s.Trim() != "") { int c = Int32.Parse(s); JoyData[cntwrite] = c; //adds each new value split(s) from SerRead string to JoyData array ++cntwrite; if (cntwrite > 6) //reset cntwrite for next time serial data is recieved { cntwrite = 0; } } } // //Graph // int x = JoyData[0] / 2; int y = JoyData[1] / 2;
Bitmap bmp = new Bitmap(512, 512); Graphics g = Graphics.FromImage(bmp); //draw axis lines g.DrawLine(new Pen(Color.Black, 2), 0, 240, 512, 240); g.DrawLine(new Pen(Color.Black, 2), 253, 0, 253, 512); // let's draw a coordinate g.DrawString("•", new Font("Calibri", 18), new SolidBrush(Color.Red), y - 12, x - 30);
PictureBox display = new PictureBox(); display.Width = 512; display.Height = 512; this.Controls.Add(display); display.Location = new Point(500, 5); display.Image = bmp; } }
public void Read() { while (port.IsOpen) { try { string message = port.ReadLine(); this.SetText(message); } catch (TimeoutException) { } } }
private void Form1_FormClosed(object sender, FormClosedEventArgs e) { readThread.Abort();
port.Close(); } } }
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #27 on: November 13, 2011, 05:44:48 pm » |
The first two lines should define class level variables. The next two should be in the Form_Load method, so they are done once. PictureBox display = new PictureBox(); display.Width = 512; display.Height = 512; this.Controls.Add(display); display.Location = new Point(500, 5); display.Image = bmp;
All this code should be elsewhere, too. Most likely the Form_load() method. You don't want to do this every time serial data is received.
Logged
Offline
Sr. Member
« Reply #28 on: November 13, 2011, 05:55:51 pm » |
haha funny how this works  i was messing around with my code before you just posted, and did all of that, but it still doesn't work. it will display the X and Y axis when the form starts, but then it should write the dot to screen after splitting the incoming serial data; no dots are displayed on the screen though. ive tried display.Update(); etc and no luck. then i tried "this.Refresh();" under SetText after writing the new dot for X/Y and it works!!! see pic below. can i make it so that it gets rid of the previous dots so theirs not dots all over? also the x any y axis' are flipped(like left is right etc), any tips? namespace CommunicateWithArduino { public partial class Form1 : Form { public static System.IO.Ports.SerialPort port; delegate void SetTextCallback(string text);
private static Bitmap bmp = new Bitmap(512, 512); Graphics g = Graphics.FromImage(bmp); private PictureBox display = new PictureBox();
btnConnect.Enabled = false; comPort.Enabled = false; sendBtn.Enabled = true; } private void Form1_Load(object sender, EventArgs e) { foreach (string s in SerialPort.GetPortNames()) { comPort.Items.Add(s); } comPort.SelectedIndex = 0;
int cntwrite = 0; foreach (string s in split) { if (s.Trim() != "") { int c = Int32.Parse(s); JoyData[cntwrite] = c; //adds each new value split(s) from SerRead string to JoyData array ++cntwrite; if (cntwrite > 6) //reset cntwrite for next time serial data is recieved { cntwrite = 0; } } } //Graph int x = JoyData[0] / 2; int y = JoyData[1] / 2; // let's draw a coordinate g.DrawString("•", new Font("Calibri", 18), new SolidBrush(Color.Red), x - 12, y - 30); this.Refresh(); } }
port.Close(); } } } And really, Thanks alot !!
« Last Edit: November 13, 2011, 08:04:22 pm by sirbow2 »
Logged
