Global Moderator
Boston area, metrowest
Online
Brattain Member
Available for Design & Build services
« Reply #30 on: November 18, 2011, 09:12:58 pm » |
I wasn't showing a TX LED, only RX, driven by D25. The Activity LED is driven when SCK is high (D13).
The shrunken ATMega32U4 design I started from didn't have a TX LED so didn't tie up a pin with one either.
Logged
Offline
Newbie
« Reply #31 on: November 18, 2011, 10:56:48 pm » |
Crossroads, that question was for fm. :-)
Logged
Panucatt Devices
Málaga, Spain
Online
Edison Member
« Reply #32 on: November 19, 2011, 08:21:34 am » |
Hi CrossRoads, the activity LEDs should be fine. Going through the data sheet suggests so. Any way, we will soon know I've ordered a batch for distributing to the chaps on the other thread, they should be arriving the week after next.
Logged
Offline
Newbie
« Reply #33 on: November 19, 2011, 12:34:56 pm » |
Hi CrossRoads, the activity LEDs should be fine. Going through the data sheet suggests so. Any way, we will soon know I've ordered a batch for distributing to the chaps on the other thread, they should be arriving the week after next. [/quote] fm, I tried it already, it is ground switched when using the arduino boot loader(LED pin is always high). Roy
Logged
Panucatt Devices
Málaga, Spain
Online
Edison Member
« Reply #34 on: November 19, 2011, 12:54:08 pm » |
Hi Roy, thanks for the feedback. Will see how it looks.
What happens after the boot loader ends? Have you tried while sending information through Serial (i.e. the CDC serial) on a sketch?
Logged
Offline
Newbie
« Reply #35 on: November 19, 2011, 01:35:41 pm » |
FM,
It runs the program after the boot loader ends(takes about 3~4 seconds on my board).It sets up the USB serial stuff and make use of the RX/TX LEDs. Make sure you get the latest leonardo boot loader from Arduino's Github pages, the one from RC2 is messed up.
I tried running the example serial sketch and the RX and TX LEDs flash as expected.
I changed the fuses to activate the HWB pin and running without the bootloader disables the serial and the RX/TX LEDs( but TX pin is held low so LED is always turned on)
Roy
« Last Edit: November 19, 2011, 01:38:24 pm by roypogi »
Logged
Panucatt Devices
Málaga, Spain
Online
Edison Member
« Reply #36 on: November 19, 2011, 04:49:28 pm » |
Thanks for the info. Cheers roypogi
Logged
Málaga, Spain
Online
Edison Member
« Reply #37 on: November 24, 2011, 05:51:54 pm » |
Though I would share that the vinciDuino boards are on their way and soon we will get our hands on with them. This is how they should look. We will keep you posted.
Logged
Global Moderator
Online
Brattain Member
« Reply #38 on: November 24, 2011, 10:22:35 pm » |
Looks nice. I Philosophically disagree with making SCD/SDL moved away from A4/A5, just because it means any shields that used SCL/SDA will now need some wires added to get those signals. Some jumpers or solder pads to make that an option would have worked.
Logged
nr Bundaberg, Australia
Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
« Reply #39 on: November 24, 2011, 10:34:21 pm » |
Just a small thing, the overlay for D10-13 has the 10s digit on the bottom, I would think it should be on the top.
Is the SDA/SCL placing what the official board will be doing?
______ Rob
Logged
Greenville, IL
Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
« Reply #40 on: November 24, 2011, 10:58:28 pm » |
Your right, the pin listing puts SCL/SDA on the other side of the board. Correct? // D2 PD1 SDA SDA/INT1 // D3# PD0 PWM8/SCL OC0B/SCL/INT0
Logged
Global Moderator
Online
Brattain Member
« Reply #41 on: November 24, 2011, 11:31:16 pm » |
Yes, PD0, PD1 are the SCL/SDA line.
Logged
Global Moderator
Online
Brattain Member
« Reply #42 on: November 24, 2011, 11:31:42 pm » |
Found this listing of pins here (which did not paste in nicely at all) http://morecatlab.akiba.coocan.jp/lab/index.php/2011/09/leonardo-on-arafruit-32u4/?lang=en // ATMEL ATMEGA32U4 / ARDUINO LEONARDO // // D0 PD2 RXD1/INT2 // D1 PD3 TXD1/INT3 // D2 PD1 SDA SDA/INT1 // D3# PD0 PWM8/SCL OC0B/SCL/INT0 // D4 A6 PD4 ADC8 // D5# PC6 ??? OC3A/#OC4A // D6# A7 PD7 FastPWM #OC4D/ADC10 // D7 PE6 INT6/AIN0 // // D8 PB4 ADC11/PCINT4 // D9# A8 PB5 PWM16 OC1A/#OC4B/ADC13/PCINT5 // D10# A9 PB6 PWM16 OC1B/0c4B/ADC12/PCINT6 // D11# PB7 PWM8/16 0C0A/OC1C/#RTS/PCINT7 // D12 A10 PD6 T1/#OC4D/ADC9 // D13# PC7 PWM10 CLK0/OC4A // // A0 PF7 ADC7 // A1 PF6 ADC6 // A2 PF5 ADC5 // A3 PF4 ADC4 // A4 PF1 ADC1 // A5 PF0 ADC0 // // New pins D14..D17 to map SPI port to digitial pins // // D14 PB0 RXLED,SS/PCINT0 // D15 PB1 SCK,PCINT1 // D16 PB2 MOSI,PCINT2 // D17 PB3 MISO,PCINT3 // // TXLED PD5 // RXLED PB0 // HWB PE2 HWB And from adafruit re: their ATMega23U4 breakout board http://www.ladyada.net/wiki/products/atmega32u4breakout/index.htmlYou can use this board with Arduino v1.0 (RC2 or higher) by selecting Leonardo as the board type, and the matching serial port. The Arduino pins are as follows PB0 - digital 14 / also RX LED PB1 - digital 15 / SPI SCK PB2 - digital 16 / SPI MOSI PB3 - digital 17 / SPI MISO
PB4 - digital 8 PB5 - digital 9 PB6 - digital 10 PB7 - digital 11
PC6 - digital 5 PC7 - digital 13
PD0 - digital 3 PD1 - digital 2 PD2 - digital 0 / serial RX PD3 - digital 1 / serial TX PD4 - digital 4 / A6 PD5 - used as Serial TX LED PD6 - digital 12 PD7 - digital 6
PE2 - unused - HWB PE6 - (also the green BOOT LED) digital 7
PF7 - A0 PF6 - A1 PF5 - A2 PF4 - A3 PF1 - A4 PF0 - A5
Note that some pins are used as the RX/TX LEDs and so you shouldnt use them in your code because the IDE 'takes over' the pins for LED blinking
Logged
Global Moderator
Online
Brattain Member
« Reply #43 on: November 25, 2011, 12:54:31 am » |
I've been reviewing the ATMega32U4 pins usage, looking for ways to make a Leonardo Clone compatible with existing shields. This chart captures what I think would be a more compatibe usage of the mixed up IO that Atmel has for this part. With some 0.025" square posts & jumpers, or solder bridges, the 6 additional pins could be brought out as well. The 2 8-pin ports and the 6 pin port could be conveniently left grouped together for direct port manipulation of complete ports. What's the group think on this vs the current Leonardo declarations? http://www.crossroadsfencing.com/pin_usage_review.pdf
« Last Edit: November 25, 2011, 12:59:36 am by CrossRoads »
Logged
Málaga, Spain
Online
Edison Member
« Reply #44 on: November 25, 2011, 02:10:24 am » |
@graynomad - well I suppose you are right about the orientation, but it depends if you read them from the board out to the board in. Don't know really I guess is a question of taste.
@crossroads - I also agree with you that they should have maintained the pinout for the I2C and SPI. There are a good range of shields out there that use these features. A message exchange with David from the Arduino team, says that they made a trade off and that they have informed shield developers about it in advance.
Don't agree that much, in the sense that PWM placement, from a shield perspective is not as important as these othe two interfaces.
« Last Edit: November 25, 2011, 02:14:54 am by fm »
Logged
