Topic: Leonardo Clone out already! (Read 42038 times) previous topic - next topic
CrossRoads
Saw this in the Spanish Forum
http://arduino.cc/forum/index.php/topic,78600.0/topicseen.html
homemade board with ATmega32U4, uses built in USB interface
http://txapuzas.blogspot.com/2009/12/paperduino-leonardo-clon-de-arduino.html
cyclegadget
  I for one am excited! Looking at the datasheet it seems that chip pins 10 and 11 are for the USB communication. They say (PDI/PCINT2/MOSI) PB2.....PDO/PCINT3/MISO) PB3.
Newark price/ eagle file / and datasheet:
http://www.newark.com/atmel/atmega32u4-au/ic-8bit-mcu-megaavr-16mhz-tqfp/dp/26R5633?Ntt=ATmega32U4
Features
• High Performance, Low Power AVR® 8-Bit Microcontroller
• Advanced RISC Architecture
- 135 Powerful Instructions - Most Single Clock Cycle Execution
- 32 x 8 General Purpose Working Registers
- Fully Static Operation
- Up to 16 MIPS Throughput at 16 MHz
- On-Chip 2-cycle Multiplier
• Non-volatile Program and Data Memories
- 16/32K Bytes of In-System Self-Programmable Flash (ATmega16U4/ATmega32U4)
- 1.25/2.5K Bytes Internal SRAM (ATmega16U4/ATmega32U4)
- 512Bytes/1K Bytes Internal EEPROM (ATmega16U4/ATmega32U4)
- Write/Erase Cycles: 10,000 Flash/100,000 EEPROM
- Data retention: 20 years at 85°C/ 100 years at 25°C(1)
- Optional Boot Code Section with Independent Lock Bits
In-System Programming by On-chip Boot Program
True Read-While-Write Operation
All supplied parts are preprogramed with a default USB bootloader
- Programming Lock for Software Security
• JTAG (IEEE std. 1149.1 compliant) Interface
- Boundary-scan Capabilities According to the JTAG Standard
- Extensive On-chip Debug Support
- Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface
• USB 2.0 Full-speed/Low Speed Device Module with Interrupt on Transfer Completion
- Complies fully with Universal Serial Bus Specification Rev 2.0
- Supports data transfer rates up to 12 Mbit/s and 1.5 Mbit/s
- Endpoint 0 for Control Transfers: up to 64-bytes
- 6 Programmable Endpoints with IN or Out Directions and with Bulk, Interrupt or
Isochronous Transfers
- Configurable Endpoints size up to 256 bytes in double bank mode
- Fully independent 832 bytes USB DPRAM for endpoint memory allocation
- Suspend/Resume Interrupts
- CPU Reset possible on USB Bus Reset detection
- 48 MHz from PLL for Full-speed Bus Operation
- USB Bus Connection/Disconnection on Microcontroller Request
- Crystal-less operation for Low Speed mode
• Peripheral Features
- On-chip PLL for USB and High Speed Timer: 32 up to 96 MHz operation
- One 8-bit Timer/Counter with Separate Prescaler and Compare Mode
- Two 16-bit Timer/Counter with Separate Prescaler, Compare- and Capture Mode
- One 10-bit High-Speed Timer/Counter with PLL (64 MHz) and Compare Mode
- Four 8-bit PWM Channels
- Four PWM Channels with Programmable Resolution from 2 to 16 Bits
- Six PWM Channels for High Speed Operation, with Programmable Resolution from
2 to 11 Bits
- Output Compare Modulator
- 12-channels, 10-bit ADC (features Differential Channels with Programmable Gain)
- Programmable Serial USART with Hardware Flow Control
- Master/Slave SPI Serial Interface
- Byte Oriented 2-wire Serial Interface
- Programmable Watchdog Timer with Separate On-chip Oscillator
- On-chip Analog Comparator
- Interrupt and Wake-up on Pin Change
- On-chip Temperature Sensor
• Special Microcontroller Features
- Power-on Reset and Programmable Brown-out Detection
- Internal 8 MHz Calibrated Oscillator
- Internal clock prescaler & On-the-fly Clock Switching (Int RC / Ext Osc)
- External and Internal Interrupt Sources
- Six Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down, Standby, and Extended Standby
• I/O and Packages
- All I/O combine CMOS outputs and LVTTL inputs
- 26 Programmable I/O Lines
- 44-lead TQFP Package, 10x10mm
- 44-lead QFN Package, 7x7mm
• Operating Voltages
- 2.7 - 5.5V
• Operating temperature
- Industrial (-40°C to +85°C)
• Maximum Frequency
- 8 MHz at 2.7V - Industrial range
- 16 MHz at 4.5V - Industrial range
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
CrossRoads
More discussion on the Spanish thread shows this too:
http://ladyada.net/products/atmega32u4breakout/
with links to software for the USB stuff.
CrossRoads
Atmel summary datasheet
http://www.atmel.com/dyn/resources/prod_documents/7766S.pdf
& other interesting info
http://www.atmel.com/dyn/products/product_docs.asp?category_id=163&family_id=607&subfamily_id=760&part_id=4317
CrossRoads
How about an Uno-like version using the ATMega32U4 chip like Leonardo/Teensduino?
I think I have this one pretty far along. Still thinking how to bring the 6 extra IO pins out.
frank26080115
Uno-like? You mean physically? Have you seen
http://code.google.com/p/micropendous/
Freelance engineer, consultant, contractor. Graduated from UW in 2013.
CrossRoads
Yes, physically, fully shield compatile.
Had not seen Micropendous, looks similar but uses the AT90USB1287 instead and adds a few more features like I did with my ATMega 1284 Bobuino.
No end of variety out there!
cyclegadget
  I was wondering how long it would take you to make your own board CrossRoads! As far as the extra I/O pins, I think they could be put on the end similar to the Mega. I think you just about have to, in order to make it shield compatible.
Nice work!
CrossRoads
I think it's done...
cyclegadget
  I honestly I don't need anymore boards but, I still would like to build a couple of these. If you are going to have them made I would take 2.
CrossRoads
Maybe I'll order up 10 bare boards from iteadstudio then! Lets see if anyone else is interested.
retrolefty
You seem to have both a power select switch or jumper and also a auto-voltage selector/FET. How are both those features going to work together?
Lefty
CrossRoads
Hmm,  let me tweak that a little. Need 5V on the USB power pins to receive D-/D+, that's not arranged qute right.
Want the option to power everything from Vin/external 5V, or power everything from USB, or power everything from Vin/external 5V and keep USB alive while not powering from USB.
westfw
Leonard itself isn't out yet, right?  So in theory the pin mapping that it will use isn't known for sure?  (there is a pins_arduino.h file for it in the v1 release candidate distributions.)
I've "always" wanted to put a bigger chip on the standard arduino board, and make the extra pins do duty as extra features (so the upload port would be different that pins 0/1, and the ISP port would be different than 11/12/13, and maybe there would be some extra peripherals on the board that didn't interfere with the standard "pins."  Sorta like the extra LED on ChipKit.)
frank26080115
#14
Nov 14, 2011, 07:02 am Last Edit: Nov 14, 2011, 07:04 am by frank26080115 Reason: 1
err... where's the 3.3V supply?
I highly recommend running the entire circuit at 3.3V instead of 5, honestly, how many 5V devices are being used vs how many 3.3V devices there are?
