Loading...
Pages: 1 [2] 3 4 5   Go Down
Author Topic: Opel TID Display  (Read 7781 times)
Serbia
Offline Offline
Newbie
View Profile
Good job Giovanni83, nicely done. Now I can't wait my Arduino to arrive. I plan to modify MPGuino to display data on stock display in my Astra instead of 16x2 originally used in the project.
http://ecomodder.com/wiki/index.php/MPGuino
« Last Edit: December 31, 2012, 11:19:10 am by bobale » Logged
Offline Offline
Newbie
View Profile
added a couple of functions, like the bargraph and the ability to write/delete only a substring of characters
opelTiD 1.1
@bobale
cool project. In fact i did this library to use my corsa display with the OBDuino
Logged
Serbia
Offline Offline
Newbie
View Profile
I've actually bought Arduino solely because of OBDuino (already have TI Launchpad, and it was enough for my needs). I really appreciate your effort to adapt existing code to work with Arduino.
Offtopic: which Corsa do you have? smiley
Logged
Offline Offline
Newbie
View Profile
Quote
an old corsa b 1.0 that  keeps hangin on
Logged
Serbia
Offline Offline
Newbie
View Profile
It's not powerful, but at least it likes to rev, and that 3-cylinder configuration gives it a nice sound.
God, I can't wait for my Arduino to arrive, I really want to make this TID+MPGuino thing work.
Logged
2nd star on the right
Offline Offline
Jr. Member
Everything I am is classified under the official secreats act!
View Profile
WWW
Thanks for posting, I was looking at doing some mods to my MKIV (G) Astra and came across this.
Will this work for a mega adk?
However the Haynes Manual (UK service book maker) Has the pins as 9, 10,11, (8?) and 12 as (as previously noted) the road speed signal but the Haynes diagram is for the Multi display (I am a TID user swell!).
I haven't had my TID out since a painted my dash so I have a question.
Does the MID & TID have the same connector and pin count?
Also how hard would it be to also used an OLED display (Adafruit unit) with the TID?
Logged
Sorry for the noobish post but my knowledge is 10 years out of date!
Serbia
Offline Offline
Newbie
View Profile
No, TID and MID don't have same pinout. Even connector is different. Road speed can be picked up somewhere near instument panel/speedo.
Logged
Offline Offline
Newbie
View Profile
Quote
i don't know about the MID, but if you need the pinout for the TID here is a good link:
TID page
Quote
i tested it with an old mega board and compiled for arduino 1.x, i can't think of any reason why it shouldn't work with the adk
« Last Edit: January 09, 2013, 02:18:20 pm by Giovanni83 » Logged
Offline Offline
Jr. Member
View Profile
WWW
I'm glad you said that as i'm using a maga adk and 1.+ process.
Thanks,just need to get a spare display to play with.
Your link doesn't work.
« Last Edit: January 09, 2013, 02:06:00 pm by AJB2K3 » Logged
Offline Offline
Newbie
View Profile
Quote
sorry, fixed.
Logged
Offline Offline
Jr. Member
View Profile
WWW
Can you post Pictures of your setup and connections please?
Logged
Offline Offline
Newbie
View Profile
i'm afraid a picture wouldn't be of much help, but here is how i connected the tid to my mega
tid connector pin
1   -> +12 V
2   -> disconnected
3   -> ground
4   -> disconnected
5   -> disconnected (i tried this to +12 but the tid goes off... even if it shouldn't)
6   -> disconnected
7   -> disconnected
8   -> +12 V
9   -> pin 5 on my mega
10  -> pin 6 on my mega
11  -> pin 7 on my mega
12  -> disconnected
worth to mention that connections for 9,10,11 needs to be configured when including the library into your project (see tid.h)
Logged
Offline Offline
Jr. Member
View Profile
WWW
Strange dunno why it's doing that.
And the mega works fine with the coms lines!
Ok something I came across on a car forum is that, some hoe the display is able to retrieve error codes from the edu.
Is it possible to get the arduino to both read and write on the i2c bus?
« Last Edit: January 11, 2013, 01:32:40 am by AJB2K3 » Logged
Offline Offline
Newbie
View Profile
while inside my car, i could press both buttons of my display and after a while it would show me the speed and then show a "test screen" with all characters lit. Once removed from the car, connected as i told in the post above and powered up, doing the same operation made all stored fault codes appear in sequence. I'm not sure why this doesn't happen when mounted inside the veichle, nor if those codes can be retrieved from the tid, all i know is that read operations on i2c bus need a 1 after the address, so in this case the address byte becomes 0x95
Logged
Offline Offline
Newbie
View Profile
Thanks for the OpelTID library
Unfortunately I’ve tried to use it, but it's not working.
I'm using the following code, and the only thing I see is sometimes a CD symbol  : http://pastebin.com/2jHE4zxh
I can change the symbol by changing the the value of  i
But I'm not seeing any text.
I'm using a UNO R3 and i've tried 2 TID.
What I’m doing wrong ?
Roel
Logged
Pages: 1 [2] 3 4 5   Go Up
Print
Jump to:
