Topic: Opel TID Display (Read 79686 times) previous topic - next topic
Giovanni83
Hi Anon
Quote
Is there any working "method" / library to send text and symbols to the Display? Additionaly I would like to have something like a "example" code, which sends a simple "Hello world" to the display, to have something which I can begin learn with.
if your TID looks like this (well, minus the color) then you can find a working library in the post just above yours. In the library header there is a brief description of how methods works, but if you need help, just ask here.
Quote
Is there any "character table"? Is it possible to send only pre-defined characters and symbols, or it is possible to enable only single segments in order to "build" your own symbols?
As far as i could understand, you can only display letters (uppercase), numbers and few symbols (like + - . *). That being said, maybe some lower level communication could allow doing what you ask, but i don't have any information on the subject.
Quote
Is it possible to set up the TiD´s clock via Arduino? I am unsure if the TID get its time from the radio in case its connected, but in case its true, then there should be a method to forward received time from GPS/DCF to the TID´s clock.
Again, not that i know. The clock is run by a separate section, so the tid displays either the clock or what's incoming from the communication line, and wich one is selected by the voltage on a specific pin. Then again, the tid seems to store fault codes from the ecu, so there is probably more happening "under the hood", but i don't know how to access it.
Anon2014
Quote
These Faultcodes are only TID relevant.
As far as I understand from the schematics, there happens only a "Communication" over these wires.
9    SCL
10    MRQ
11    SDA
the rest of them are only "Powersupply" and wires to the "Temperature" sensor. As far as we know, the 9 - 10 - 11 are connected to the Opel radio.
When you remove the radio (as I did) then there appear a faultcode in the TID if you press the two buttons simultaneously.
I don´t recall the Faultcode number, I can look up it later.
The second Code which appeared when I removed the whole TID from the car, and connected it only to a 12 V supply was something like F171
this means a problem with the temperature sensor.
So I don´t think that there is any connection to the ECU, considering the fact that I can read out the faultcodes with my laptop and can confirm that no faultcodes were stored in my ECU at the time the TID diplayed them.
Quote
But You have to tell the TID what char to display? How do you send a command to display "ABC" for example?
I mean on low-level.
After reading the PDF here: http://wiki.carluccio.de/index.php/Opel_TID
I couldn´t find any hints, which bits or bytes send to the TID stands for which character.
So how did You determine them?
Quote
Well to understand the C language to its full detail is still a little hard for me.  :D But I will try.
Giovanni83
Quote
Well to understand the C language to its full detail is still a little hard for me.  smiley-grin But I will try.
what, in terms of coding capabilities, you need to display a message on your TID (again, if is the 8 carachters kind) is far from being a deep knowlege of the c language.
the following example displays the message "ABC" on the tid
Code: [Select]
#include <TID12.h>
TID MyTid(7,5,6);
MyTid.space1_init(0,7);
    MyTid.display_message("ABC",1,1);
if you have any question regarding this library i would be happy to help
Anon2014
Thx for the code, I will try it out. And yes I have a 8-char TID
But what I meant, is how do you exactly convert the "ABC" to the "TID-Signal"
Giovanni83
Quote
basically, the ASCII number corresponding to the carachter is sent to the display in serial fashion. The uppercase A, for example, corresponds to binary 1000001, so this number is sent to the tid, using serial communication with a specific protocol. In the carluccio page you linked before are specified all the timings and rules you need to follow in order to succesfully transmit data. Obviously a detailed explanation would be a bit longer, but the purpose of the library is to avoid users having to deal with all of this  :)
Anon2014
Quote
Well it worked .. at least a bit.
I could send a simple text to the TID. with
Code: [Select]
#include <TID12.h>
TID MyTid(7,5,6);
   MyTid.display_message("12345678",1,1);
Although its not dynamic but static Text, there is already a problem. Every minute (when the clock on the TID counts a new minute) the display clears for 0,5-1 sec.
Nevermind when I try out two different strings for example:
Code: [Select]
MyTid.display_message("87654321",1,1);
It works somehow, but the timing is anything but accurate  XD
I mean instead of this pattern: -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
Its something like this: ---___-_-__--____----__--______-___--_-_-_-_-_-_--_-____--___----
I tried to remove the delays to add another delays, to raise this speed value (X) in "MyTid.display_message("87654321",X,1);"
But no success.
Additionally I would like to try the following to have some dynamic output to send to the TID like if I would want to display the engines "RPM" or something. Smooth and fast refresh rate is very important.....:
Code: [Select]
#include <TID12.h>
TID MyTid(7,5,6);
 int i = 0;
 for(i=0;i<1000;i++)
 MyTid.display_message(i,1,1);
it says.
Code: [Select]
sketch_may12a.ino: In function 'void loop()':
sketch_may12a:14: error: invalid conversion from 'int' to 'const char*'
sketch_may12a:14: error: initializing argument 1 of 'String::String(const char*)'
Giovanni83
#81
May 12, 2014, 09:42 pm Last Edit: May 12, 2014, 09:44 pm by Giovanni83 Reason: 1
Quote
not sure if there is a way to inibith that, but happens on mine and other's too. Can't remember if someone already posted why it happens and how to avoid that.
Quote
it works somehow, but the timing is anything but accurate  smiley-lol
try with the following code:
Code: [Select]
MyTid.clear_space(1);
Quote
it says.
Code:
just remember that the display_message method (or was it called function?  :smiley-red:) requires a string argument. I'm shure there are lighter and more elegant ways to do this, but i would just do this:
Code: [Select]
MyTid.display_message(String(i),1,1);
a final note: don't expect crazy refresh rates from this display. I am shure that the library itself could be improved a lot by a good programmer (which certainly i am not  :smiley-sweat:) but in the end the timings of the tid need to be respected for everything to work.
To get more speed, you can try tweaking a parameter in the TID12.h header
Code: [Select]
#define tid_delay 25
seems to me that with 25 everything works fine even on the atmega328 and the speed is reasonable, but you can try and reduce it.
Anon2014
Well its a bit better but something like this
https://www.youtube.com/watch?v=Gck8UfNMQiw
would still be impossible.
I don´t know, today when I ´ve connected the arduino (which is on an experimental board along with the TID wiring) I got an "unknown device".
When I´ve disconnected the 12 V powersupply adapter for the TID which is on a common GND with the arduino. The arduino was recognized correctly.
Maybe there is an interference. Between the powersupply and arduino. (Arduino get its powersupply from the USB port and the TID is connected to a separate circuit only the TID´s GND (and of course the SCL/SDA/MRQ) is connected to the Arduino)
btw
Quote
why "even" on the "atmega328" what´s bad about it? Are there better alternatives?
Giovanni83
Quote
nothing bad about it, but initially i developed the library on arduino mega (atmega1280), then when i tried it on the atmega328 was sluggish, so i reworked the code.
btw, to make the text scroll like in the video you posted, you just have to write a string longer than the space, and for the meter using all the symbols use the bargraph function
Code: [Select]
#include <TID12.h>
TID MyTid(7,5,6);
int i=0;
   i++;
   if (i>255) i=0;
   MyTid.display_message("THIS STRING IS UNNECESSARILY LONG. NOW IT'S EVEN LONGER  ",30,1);
   MyTid.bargraph(i);
you can also write up to 3 different strings, each one rolling at a different speed
Code: [Select]
#include <TID12.h>
TID MyTid(7,5,6);
MyTid.space1_init(0,2);
MyTid.space2_init(3,5);
MyTid.space3_init(6,7);
    MyTid.display_message("ABCD ",5,1);
MyTid.display_message("1234 ",15,2);
MyTid.display_message("MNO",30,3);
also, from the description your circuit seems fine, just double check that there are no bad connections or short circuits
Anon2014
Yes the first one seems to work pretty well.
Maybe I just don´t get the concept of "C".
But Anyway I used this one
Code: [Select]
#include <TID12.h>
TID MyTid(7,5,6);
int i=0;
   delay(200);
   i++;
   if (i>255) i=0;
   MyTid.display_message(String(i),30,1);
   MyTid.bargraph(i);
   Serial.println(i);
To be able to compare the serial output with the actual output of the TID
But there are many glitches, or numbers left out. I will upload a video of it soon if it helps.
Btw I am using the Arduino Nano, if I didn´t mentioned it before.
If I understood it correctly the "30" in " MyTid.display_message(String(i),30,1);" is the scrolling speed, although its not necessary when the string is max 8 chars long. But if I set it to "1" in this "dynamic" case its much more buggy then. Even if there is no scrolling just a updating number.
So I don´t understand what happens when you add a "delay(X)" in your Loop function, and if it affect or even is a conflict between this two values.
Let´s take this as an example:
Code: [Select]
#include <TID12.h>
TID MyTid(7,5,6);
int i=0;
   i++;
   if (i>255) i=0;
   MyTid.bargraph(i);
It´s pretty fast scrolling text, so when I put a delay in it, it should reduce the scrolling speed then or not?
So is this "30" equal to a "delay(30)" so the program stucks in the "display_message" function for 30ms, before it continues?
Or does the "loop()" function go on nevermind whatever happens in "display_message()"?
Giovanni83
the scrolling mechanism is handled inside the tid12 library. To avoid wasting cpu cycles the scroll timing, wich is the time the function needs to wait between one movement of the string to the left and the next, is not done using a delay function. Say the display_message function has just shifted the string one step left: the current time (millis()) is marked down in a "timestamp" variable and the function is not executed again until the value of millis() is >= timestamp+timing, meanwhile the cpu can keep doing is business. When you set the speed value in the display_message call, basically you are changing the timing value in the example above (and btw, in the tid12.h there are some brief explanations to all the functions available and their parameters).
Now, more to the point of your questions
Quote
i got to admit that i never run this test. There is a speed value at wich there are no glitches?
Quote
still an atmega 328/168, so no problems here
Quote
well, this is a consequence of the mechanism explained at the beginning: even if the string is shorter than the space available, the display it's not actually updated until the required time is passed, so the lower the speed, the "buggier" it will look.
Quote
-the cpu waits for  delay(x) milliseconds
-then executes the display_message function
-which checks if the required amount of time, dependant from the speed argument, is elapsed
-if the above it's true, the display is updated, if not, the  program exits the function
-and the cpu waits again for delay(x) milliseconds
so if  delay(x) is smaller than the timing that display_message must wait, you can have a counter (like i++) that increases without being showed on the tid.
Quote
yes it should
Quote
no, the speed parameter is just an arbitrary number for setting the speed, so 1=slowest and 255=fastest. The actual time between updates is calculated as
1000/speed (ms)
so for a speed of 30 should be around 33ms, while for a speed of 1 is one second. Before you start guessing why i choose those numbers: well, i just wrote the function this way to have the crude mechanism going, and then never bothered with fine tuning the values :smiley-sweat:
Anon2014
So you mean, once called "display_message" or "clear_space". Everytime a timestamp is stored and the fuction refuse to change or display content for the given time in ms even if I call it in the program?
Well ok this explains it, and it explain the glitches and lost values from the "i" variable, because I was indeed expecting the "display_message" function is "forced" to display the string when you call it.
But with this "independent" timing you need a different code. And take care of the right delays. I will play with it and see if it helps.
Giovanni83
Quote
true for display_message, while clear_space executes every time it's called
Quote
the idea behind this is to avoid wasting cpu cycles on updating the display when it's not a prioity, but if you want a quick refresh just use the maximum speed value, you shouldn't really worry about timing.
Sepp1593
Hello everyone!
I just got an old Opel Corsa B and i wrote a sketch on arduino which displays the car's speed and rpm on the TID. But it's not that fast. It updates the display only about 1-2 times a second.  :~
The engine's rpm signal is taken from the green wire on pin 9 on the dashboard connector.
Speed signal from pin 12 on the TID connector.
I'm not that experienced in programming so i would appreciate any suggestions for improvements or other features.
Thanks Giovanni83 for the library!  :)
So here is the code:
Code: [Select]
#include <TID12.h>
TID MyTid(7,5,6);
const int sdv = 8;
const int rpm = 9;
int sdvvalue;
int rpmvalue;
float sdvfloat;
float rpmfloat;
int sdvstate = 0;
int rpmstate = 0;
int sdvstateold = 0;
int rpmstateold = 0;
int sdvhcount = 0;
int rpmhcount = 0;
int sdvbreak = 0;
int rpmbreak = 0;
int start = 0;
int rpm2s = 0;
int rpm3s = 0;
int rpmh = 0;
int rpmh2 = 0;
int sdv2s = 0;
int sdvh = 0;
unsigned long time;
unsigned long timeold;
unsigned long timediff;
unsigned long timediff2;
char rpmdisp[4];
char sdvdisp[3];
 MyTid.space1_init(0,3);
 MyTid.space2_init(5,7);
 pinMode(sdv, INPUT);
 pinMode(rpm, INPUT);
 while (start == LOW)
   MyTid.display_message("OPEL",1,1);
   MyTid.display_message("ACC",1,2);
   rpmstateold = rpmstate;
   rpmstate = digitalRead(rpm);
   delay(20);
   if (rpmstate == HIGH && rpmstateold == LOW)
     start = 1;
     delay(20);
     delay(20);
     MyTid.clear_space(2);
 timeold = micros();
 while(rpmhcount < 10)
   delayMicroseconds(150);
     rpmhcount++;
   time = micros();
   timediff2 = time - timeold;
   if (timediff2 > 375000)                      //800 rpm --> 375000
     rpmbreak = 1;
 time = micros();
 rpmhcount = 0;
 timediff = time - timeold;
 rpmfloat = float(timediff);
 rpmfloat = (1 / (rpmfloat / 1000000)) * 300;                   // green wire gives 2 signals per rotation --> (10*60)/2
 rpmvalue = int(rpmfloat);
 rpmh = rpmvalue / 1000;
 rpmh2 = rpmvalue / 100;
 rpm2s = rpmh2 - (rpmh * 10);
 rpm3s = (rpmvalue / 10) - (rpmh2 * 10);
 rpmdisp[0] = '0' + rpmh;
 rpmdisp[1] = '0' + rpm2s;
 rpmdisp[2] = '0' + rpm3s;
 rpmdisp[3] = '0' + (rpmvalue % 10);
 rpmdisp[4] = '\0';
 if (rpmbreak == HIGH)
   rpmdisp[0] = '0';
   rpmdisp[1] = '0';
   rpmdisp[2] = '0';
   rpmdisp[3] = '0';
 rpmbreak = 0;
 MyTid.display_message(rpmdisp,1,1);
 if (rpmvalue < 1000)
   MyTid.bargraph(0);
 else if (rpmvalue < 1500)
   MyTid.bargraph(26);
 else if (rpmvalue < 2000)
   MyTid.bargraph(52);
 else if (rpmvalue < 2500)
   MyTid.bargraph(77);
 else if (rpmvalue < 3000)
   MyTid.bargraph(104);
 else if (rpmvalue < 3500)
   MyTid.bargraph(130);
 else if (rpmvalue < 4000)
   MyTid.bargraph(156);
 else if (rpmvalue < 4500)
   MyTid.bargraph(182);
 else if (rpmvalue < 5000)
   MyTid.bargraph(208);
 else if (rpmvalue < 5500)
   MyTid.bargraph(234);
 else if (rpmvalue < 6000)
   MyTid.bargraph(255);
 else MyTid.bargraph(255);
 timeold = micros();
 while(sdvhcount < 10)
   sdvstateold = sdvstate;
   sdvstate = digitalRead(sdv);
   if (sdvstate == HIGH && sdvstateold == LOW)
     sdvhcount++;
   //ab hier
   time = micros();
   if (timediff2 > 393750)                                        //393750 --> 5 km/h
     sdvbreak = 1;
 time = micros();
 sdvhcount = 0;
 sdvfloat = float(timediff);
 sdvfloat = (1 / (sdvfloat / 1000000)) * 1.96875;      //(1.750 / 32) * 10 = 0.546875  ,    3.6*0.546875 = 1.96875, 1.750 = tire size
   sdvvalue = int(sdvfloat);
 sdvh = sdvvalue / 100;
 sdv2s = (sdvvalue / 10) - sdvh * 10;
 sdvdisp[0] = '0' + sdvh;
 sdvdisp[1] = '0' + sdv2s;
 sdvdisp[2] = '0' + (sdvvalue % 10);
 sdvdisp[3] = '\0';
 if (sdvbreak == HIGH)
   sdvdisp[0] = '0';
   sdvdisp[1] = '0';
   sdvdisp[2] = '0';
 sdvbreak = 0;
 MyTid.display_message(sdvdisp,1,2);
Budvar10
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
