Has anyone had any success interfacing Arduino with Opel TID display? I've found many, many codes in different programming languages, but I'm not advanced enough to translate them into code which will work with Arduino.
I know that asking someone to translate code would be too much to ask, but is there any way someone could help a little here? As the code is too long to share in one post, here is the complete code
http://codetidy.com/4239/. A chunk of code is dedicated for voltage measurement and display, and I'm not interested in it, so I don't need that.
Mostly, I'm confused about these initializations:
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=0x00;
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
MCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC Clock frequency: 250,000 kHz
// ADC Voltage Reference: AVCC pin
ADMUX=ADC_VREF_TYPE & 0xff;
ADCSRA=0x85;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
Do I need any of these initializations for this code to work in Arduino?
Edit:I've found Arduino code that looks like it shoud work, but as my Arduino hasn't yet arrived, I have no way of checking it:
#include <Wire.h>
pinMode(2, OUTPUT);
Wire.begin();
digitalWrite(2, LOW);
delay(200);
digitalWrite(2, HIGH);
delay(200);
Wire.beginTransmission(0x94);
Wire.write(0x10);
Wire.write(0x01);
Wire.write(0x8C);
Wire.write(0xA4);
Wire.write(0x8A);
Wire.write(0x8A);
Wire.write(0xB5);
Wire.write(0x40);
Wire.write(0x8C);
Wire.write(0x9B);
Wire.endTransmission();
void loop() {}
It seems that this code follows procedure for sending text to the LCD:
1:Idle state all lines are high.
2:Pull MRQ low for a short period and let it go high again.
3:Send a "I2C Start"
4:Send the address byte, 0x94
5:Pull MRQ low.
6:Send 13 data bytes. (The 8 character display uses 10 databytes)
7:Let MRQ go high
8:Send "I2C Stop"
What do you guys think?
