Topic: DAC help (Read 938 times) previous topic - next topic
georgiollo
Hey everyone, I just bought a MCP4725 DAC from sparkfun online:
http://www.sparkfun.com/products/8736
This DAC has 12 bits of resolution from 0V to 5V
Now that I attached it to some speakers and made it play a simple square wave, its only making a scratching sound, like when you hook up a battery to some speakers. I was wondering if I absolutely need a negative current to work the speakers. And if so, how would I do this?
Thanks in advance for your help
Grumpy_Mike
Quote
No it will work off a single supply.
However, you can't just connect it up to a speaker because it takes much more current than the chip can supply, you will need an amplifier before the speaker. I hope you have not blown up the D/A chip by trying to draw too much current from it.
georgiollo
Then how can I generate a negative voltage? Is this AC coupling?
Grumpy_Mike
Why do you want to generate a negative voltage?
retrolefty
First you need to run the output of the DAC through a series capacitor, 1 ufd should cover low enough tones, that will remove the DC bias and give you a true AC voltage referenced to ground. Second your DAC does not have a low enough output impedenance (source current drive) to directly drive anything but a very small speaker, it really should wire to a audio preamp/amp device sized for the speaker output wattage you require.
Lefty
georgiollo
I am aware that the DAC is not powerful enough to drive large speakers ( I am currently using old laptop speakers ). And thanks lefty, i'll definitively do the capacitor thing.
Quote
Because to drive speakers you need a negative voltage, Am I wrong?
Thank you for your help
Grumpy_Mike
Yes you are wrong. Using a capacitor for coupling removes the DC bias and makes your varying DC signal into an AC one. That is also what an amplifier will do for you like I said on my first reply.
georgiollo
Thank you all for your help
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
