Topic: 50/50 Background Pulse (Read 943 times) previous topic - next topic
GreenGiant
I am starting a project, and the first thing that I need to do seems to be the most difficult, I need a constant background pulse
on for 110ms off for 110ms with very little change in the time throughout the program
what would be the best way of programming it so that it keeps that pulse, only on 1 pins (controlling an external relay)
Thanks
cmagagna
For that level of precision I think you'll have to set up a timer and flip the pin state in the interrupt routine.
See the bottom code sample here for something close to what you want:
http://www.arduino.cc/playground/Code/Timer1
Good luck!
GreenGiant
That seems to be working wonderfully
now if I need that to control something else (like when its on do this, when off do this) I can just use the if (pin used == HIGH) {do this} else if (pin used == LOW) {do this} correct?
I suppose I should explain my project a little bit, I am trying to build one of those floating message clocks (http://zedomax.com/blog/wp-content/uploads/2009/11/c778_ixp3_internet_messaging_clock.jpg)
I am tearing one down, and reworking it
I have figured out the frequency or oscillation, (thats what I needed the timer for)
Now I am trying to get it to display text (8-bit) from left to right (timer on) and then right to left (timer off)
I know that I will have to build a library with all of the letters to make life easier on myself
any help would be greatly appreciated
cmagagna
"pin used" needs to be a global or static variable, or shorthand for digitalRead(pin used), but yes that will work.
Sounds like a cool project. Post a video when you're done!
GreenGiant
update on the project,
sorry its been so long, work and school have been consuming my time
I have the arduino sending the 50/50 pulse to a relay (HB Controls HBC-11-CMX60D10) which controls the swing arm
I then have functions set up for each letter of the alphabet (including spaces)
I have a for loop set up to loop 300 or so times (30 seconds) with some do loops in it that read the sensor at the edge of the swing arc
The first do while does nothing until the sensor is tripped, the second waits until it is not sensing the arm anymore then the actual call functions are there for the letters
After is has looped the 300 times it pauses for a second and moves to another for loop that controls the second set of text with the same setup
I will post samples of my code and videos once I get the whole thing working properly
