Offline
Newbie
« on: November 13, 2011, 07:50:02 am » |
Hello everybody, I am a new user of Arduino from Spain. I have an Arduino MEGA2560 and a Ethernet Shied type ENC28J60, I have connected them & every is OK with this library: http://iteadstudio.com/application-note/ethernet-shield-go-with-arduino-libraries/I am able to do ping, like a server and like a client. But I need some suggestions. Let me explain my project: I need to extract some information from the Microsoft FSX Simulator through the TCP protocol using the IOCP software. I have checked it usig LabView environment and it works fine. But I need not to use a PC, and use only the Arduino connected to a router. It is easy, my Arduino needs to write to the server (192.2.1.2 port 8090) the next command: "Arn.Inicio:Var419" After that, I must to read the incommnig messages "Arn.Var419:xxxxxx" Must I connect the Arduino like a clent? I have tried (see bellow) this code but It doesn't work, what do you think? Thanks you very much & My best regards. Pedro
Logged
Offline
Newbie
« Reply #1 on: November 13, 2011, 07:51:20 am » |
#include <Ethernet.h>
byte mac[] = { 0x00, 0x1B, 0xB9, 0x84, 0xCB, 0x60 }; byte ip[] = { 192, 2, 1, 4 }; byte server[] = { 192, 2, 1, 2 };
Client client(server, 8090);
void setup() { Serial.begin(9600); Serial.println("Iniciando conexion FSX"); delay(100); Ethernet.begin(mac, ip); delay(5000); Serial.println("conextando a ip: 192.2.1.2.??????..."); if (client.connect()) { Serial.println("FSX Conectado----->"); client.println("Arn.Inicio:Var419"); //client.println(); delay(10000); } else { Serial.println("FSX NO conectado *********"); } }
void loop() { cnx: delay (1000); if (client.available()) { char c = client.read(); Serial.print(c); } if (!client.connected()) { Serial.println(); Serial.println("Reintentando"); goto cnx;
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #2 on: November 13, 2011, 09:52:22 am » |
If there client is no client connected, goto the start of a function that will be called again, in an infinite loop anyway. Why? I have tried (see bellow) this code but It doesn't work, what do you think? I think you need to lean a little to the left. You are blocking your screen. We can't see what the program actually does, and you haven't told us. A little farther. Still can't see. A little more...
Logged
Offline
Newbie
« Reply #3 on: November 13, 2011, 11:33:27 am » |
Thanks Paul,
I have simplified the code, still not working:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; byte ip[] = { 192, 2, 1, 4 }; //my ip byte server[] = { 192, 2, 1, 2 }; //FSX ip
Client client(server, 8090); //port must be 8090
void setup() { Ethernet.begin(mac, ip); Serial.begin(9600); delay(1000); Serial.println("Begin FSX connection"); }
client.println("Arn.Inicio:Var419"); //command from Arduino to FSX client.println(); delay (10000); rdx: // scan for responses from FSX delay (100); if (client.available()) { char c = client.read(); Serial.print(c); //link TCP messages to serial (for debugging) goto rdx; } }
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #4 on: November 13, 2011, 11:40:10 am » |
client.println("Arn.Inicio:Var419"); //command from Arduino to FSX client.println(); delay (10000); rdx: // scan for responses from FSX delay (100); if (client.available()) { char c = client.read(); Serial.print(c); //link TCP messages to serial (for debugging) goto rdx; } } The client.available() function returns the number of characters available to read. Read them in a while loop, rather than inventing your own. The goto statement has very little going for it here. I have simplified the code, still not working: You have some expectation of what the code should do. There is something that the code does. All we can tell from the information you have provided is that those two are not the same thing. We have a pretty good idea of what you expect it to do. What it actually does is a mystery. You need to clear up that mystery if you expect help.
Logged
0
Offline
Edison Member
Arduino rocks
« Reply #5 on: November 13, 2011, 01:13:26 pm » |
hadnt come across that library. Looks very simple and similar to the original ethernet shield. Are you using the ENC28J60 shield with it?? Are you using a gateway? Ive tried this and does not connect, maybe you can give me a hint., #include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; byte ip[] = { 192, 168, 1, 88 }; byte server[] = { 74, 125, 224, 72 }; byte gateway[] = {192,168,1,1};
Client client(server, 80);
void setup() { // Ethernet.begin(mac, ip); Ethernet.begin(mac, ip, gateway); //Setup ethernet client Serial.begin(9600); delay(1000); Serial.println("connecting..."); if (client.connect()) { Serial.println("connected"); client.println("GET /search?q=arduino HTTP/1.0"); client.println(); } else { Serial.println("connection failed"); } }
void loop() { if (client.available()) { char c = client.read(); Serial.print(c); } if (!client.connected()) { Serial.println(); Serial.println("disconnecting."); client.stop(); for(;;) ; } }
Logged
Offline
Newbie
« Reply #6 on: November 13, 2011, 01:43:10 pm » |
All the examples included in the ibrary works fine. I have tried all of them with my ip's.
Tomorrow I will try your code, and i will tell you about it.
Regards.
Logged
0
Offline
Edison Member
Arduino rocks
« Reply #7 on: November 13, 2011, 02:53:46 pm » |
My code is just the WebClient code that comes with the library you posted, but with a fixed gateway and changed server IP to call google. These parts... byte server[] = { 74, 125, 224, 72 }; byte gateway[] = {192,168,1,1}; Ethernet.begin(mac, ip, gateway); //Setup ethernet client
please let me know if this code works for you cause i dont understand what is happening. this is the one i used with an Arduino UNO. http://www.ebay.com/itm/170696120342?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649UQ~~60_3.JPG)
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #8 on: November 13, 2011, 05:51:33 pm » |
The code you posted looks like code for the wiznet 5100 chip. Below is what seems to be the ENC28J60 type coding. If you got ping to work, then maybe not. #include "etherShield.h"
static uint8_t mymac[6] = {0x54,0x55,0x58,0x10,0x00,0x24}; static uint8_t myip[4] = {192,168,1,15}; static char baseurl[]="http://192.168.1.15/"; static uint16_t mywwwport =80; // listen port for tcp/www (max range 1-254)
Logged
Offline
Newbie
« Reply #9 on: November 14, 2011, 12:12:22 pm » |
With the library indicated at the beginning of the topic, is valid for ENC28J60. Regards
Logged
Offline
Newbie
« Reply #10 on: November 14, 2011, 12:20:11 pm » |
please let me know if this code works for you cause i dont understand what is happening. this is the one i used with an Arduino UNO. I suppose that if you want to go out to the internet, without a router, through your PC, you need a crossover ethernet cable, take a look for this: http://www.kiranjose.com/blog/2011/09/connect-to-internet-with-arduino-mega-2560-and-enc28j60-breakout-board_crossover_ethernet_cable/Regards
Logged
0
Offline
Edison Member
Arduino rocks
« Reply #11 on: November 17, 2011, 04:49:40 pm » |
please let me know if this code works for you cause i dont understand what is happening. this is the one i used with an Arduino UNO. I suppose that if you want to go out to the internet, without a router, through your PC, you need a crossover ethernet cable, take a look for this: http://www.kiranjose.com/blog/2011/09/connect-to-internet-with-arduino-mega-2560-and-enc28j60-breakout-board_crossover_ethernet_cable/Regards no, i want to go out to the internet but i am using a router that has ip 192.168.1.1 thats why i need the gateway cause if not it does not find the router (same happens in my computers) i need to specify the routers ip.
Logged
