Topic: 3D Scanner with 2 RC Servos and a distance Sensor (Read 10609 times) previous topic - next topic
TeamMCS
Hey designer.
I wonder if you could help me, I'm thinking of extending your work with the scanner. I've been reading up on polar coordinates and I just wanted to understand how produce a 3d image.
From my understanding the scanner is at point 0, everything else is relative to the servos and distance.
When you convert to cartesian coordinates, again, they are relative. so you may have a -10, -10 (for example) where 0,0 is your scanner.
I dont know [anything] much about Mesh (or any other 3d rendering software), but from the tech specs, you just feed it a collection of cartesian readings in the right format and it'll render the result - leaving you to "clean up" the image.
Any guidance would be highly appreciated!
koyaanisqatsi
Quote
if for example you always move the scanner exactly 2m forward you can take that into account as an offset during the polar/cartesian conversion.
You could use a wheel with a 1m (or any known) circumference and a rotation sensor so that the code calculates the distance for you.  In fact, you could even make the scanner head rotate 360 degrees one rotation and then back and have it log a zig-zag helical scan of sorts.  As long as you know the traveled distance in relation to the scan head angular movement, you can calculate the 3D space.
This would give you a straight-but-bumpy map of the cave.  You would need to measure ahead and behind some distance so you could detect and calculate turns and other directional changes.
designer2k2
#17
Apr 18, 2009, 09:08 am Last Edit: Apr 18, 2009, 01:03 pm by designer2k2 Reason: 1
Thats my way of getting a image:
lets just look it up for 1 point (Code is VB.net)
1.) Origin.
the rotationpoint from the pan-servo is 0,0,0 (X,Y,Z) or 0,0(R,Angle)
2.) Where´s your scanned point.
for example the pan servo is at 50° and the tilt servo at 30°. your reading a analog value of lets say 100.
so first convert the analog value to distance:
Code: [Select]
   Public Function ADWtoDist(ByVal ADW As Integer) As String
       'If the Value is smaller as 38, the result would be biger as 300cm, what makes no sense.
       If ADW < 38 Then ADW = 38
       ADWtoDist = 10565 * ADW ^ -0.982
       'Debug.Print("Dist: " & ADWtoDist & " cm")
   End Function
3.) then we convert the polar coordinates into cartesian:
Basics: http://www.euclideanspace.com/maths/geometry/space/coordinates/polar/index.htm
in Code it looks like this:
Code: [Select]
Public Function PolarToCartesian(ByVal TiltAngle As Double, ByVal PanAngle As Double, ByVal R As Double) As Array
       'This will be 1=X,2=Y,3=Z
       Dim Result(3) As Double
       'Basic: http://www.euclideanspace.com/maths/geometry/space/coordinates/polar/index.htm
       ' x = r sin(a1) cos(a2)
       ' y = r sin(a1) sin(a2)
       ' z = r cos(a1)
       'Where a1 = TiltAngle, a2 = PanAngle, r = R
       'All Angles must be Radians, and they must be 0-180, not 0-155
       TiltAngle = TiltAngle * 180 / 155
       PanAngle = PanAngle * 180 / 155
       TiltAngle = Math.PI * TiltAngle / 180.0
       PanAngle = Math.PI * PanAngle / 180.0
       'Now they can be calculatet:
       Result(1) = (R * Sin(TiltAngle) * Cos(PanAngle)) + TextBox1.Text
       Result(2) = (R * Sin(TiltAngle) * Sin(PanAngle)) + TextBox2.Text
       Result(3) = R * Cos(TiltAngle)
       Return Result
   End Function
the 0-155 to 1-180 conversion comes from my servos, if you move them from 0-155 they make already 0-180 degrees...  ::)
4.) And know this must be saved into a file!
Easiest format is obj: http://en.wikipedia.org/wiki/Obj
example file from my scan:
Code: [Select]
v 31.9121705541201 33.5715843563032 17.1546264824741
v 33.984405250283 35.7515740185642 17.1399861761586
v 36.1267443214351 38.0053134414284 17.037524539716
v 32.3026021291672 33.9823181399808 14.1901570731361
v 32.4941081567727 34.1837823666023 13.2370150128776
v 32.8076369704424 34.5136144912581 12.3293085742347
v 32.8370021129878 34.544506603671 11.3148117078009
v 32.4527234486948 34.1402456784305 10.1785760817876
to do that in Code:
Code: [Select]
           Dim Cartesian(3) As Double
           Cartesian = PolarToCartesian(Tilt, Pan, Dist)
           Dim OutStr, OutStr2, X, Y, Z, As String
           OutStr = Nothing
           X = Replace(Cartesian(1).ToString, ",", ".")
           Y = Replace(Cartesian(2).ToString, ",", ".")
           Z = Replace(Cartesian(3).ToString, ",", ".")
           'This is the obj String:
           OutStr2 = "v " & X & " " & Y & " " & Z & vbCrLf
           RichTextBox2.AppendText(OutStr2)
5.) and at the end of a scan save it to a .obj file:
Code: [Select]
RichTextBox2.SaveFile("N:\Programme\Meshlab\ArduinoScan.obj", RichTextBoxStreamType.PlainText)
now just open this .obj file in Meshlab, and your ready to run  :)
6.) Meshlab
look here: http://philohome.com/scan3d/scan3d.htm
under "3D reconstruction" theres a perfect description on how to use Meshlab!
designer2k2
TeamMCS
Ah thats fantastic, I'll give that a go as soon as I recieve my measurer.
Thanks a lot, I'll let you know my results :)
designer2k2
somebody has taken this to the extreme: http://pruned.blogspot.com/2010/02/mapping-abysses.html
very cool stuff  8-)
TeamMCS
That's amazing, I'd love to the see the environmental re-mapping process
jyyang
Oh, what a coinsidence it is, I'v just had the same idea sience last night, when I told my friend I want to build a thing for scanning in a dark room and realizing a 3D map of that.
I never thought there would be a trailblazer on the other side of world:). Anyway, I think it is very insteresting, and I sincerely wish u acquiring a perfect success!!
