Topic: Midi JUNO 60 (DCB to MIDI converter) need help (Read 2646 times) previous topic - next topic
xarolium
Dear Diyers,
I would like to control the JUNO60 in MIDI
This old syntheziser use DCB protocol
http://en.wikipedia.org/wiki/Digital_Control_Bus
i connect the arduino like this
-DCB Tx Data -----> Arduino Rx
-DCB ground ------> Arduion Ground
I use this program to read the data who send the juno 60
Code: [Select]
int Led = 13;
int data = 0;
int count=0;
//Initialisation de la sorite de la Led et du port Rx en Midi//
///////////////////////debut de la boucle///////////////////////
 Serial.begin(31250);
 delay(100);
 if(Serial.available() > 0){// un info est elle presente en Rx
   data = Serial.read();// enregistrer cette info dans la variable Data
   Serial.begin (9600);
   Serial.print (data, HEX);
   Serial.println (" ");
   count ++;
   if (count == 7){
     Serial.print("/n");
     count =0;
That what i read on the serial monitor
I don't understand this data because at the beginning the data seem to ok and when i try to push a key the datra change and never be the same as the beginning
Is there anybody who are "friendly" with the type of protocol or maybe i dont interface it correctly
Thank you for your help
Xarolium
xray303
#1
Nov 14, 2011, 04:44 pm Last Edit: Nov 14, 2011, 05:00 pm by xray303 Reason: 1
I don't know the DVB protocol but are you sure about your baud rate ?
Because usually this kind of bad data can comes from incorrect baud rate
Edit : after checking the wikipedia page you added, it seems that the protocol have 2 stop bit.
"LSB first, 8 data bits, 2 stop bits, odd parity, and a Baud rate of 31.25kHz."
This could be the cause of your data errors
There is a post on midibox forum about this protocol (but no solution) you can maybe find useful info :
http://midibox.org/forums/topic/5013-midi-dcb/
xray303
xarolium
thank you for your help Xray303
I learned a little bit more of the UART protocol
and it work like that.
A byte is composing with:
-first one start bit = 0
-after Data bits between 5 and 9
-then a parity bit
-finaly one stop bit = 1
the different between  the DCB protocol and UART is that the start in DCB is 1 and stop Bit is 0
Do you think it's possible to change this on the Arduino UART.
xray303
It's a good question, i never tried (never needed) maybe some  Arduino Guru here could respond to that.
you can try to look at this it could help :
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1243894373/15
http://code.google.com/p/arduino/issues/detail?id=573
http://www.arduino.cc/en/Tutorial/SoftwareSerial
xarolium
#4
Nov 18, 2011, 05:19 pm Last Edit: Nov 18, 2011, 05:49 pm by xarolium Reason: 1
thank you
the last link is very useful
on this page he said:
Definitions Needed:
#define bit9600Delay 84
#define halfBit9600Delay 42
#define bit4800Delay 188
#define halfBit4800Delay 94
But how he can find 84 microseconds to generate 9600baud
f=1/T       F= 1/0,000084 = 11905 hz approximately
How can i find the right frequency to generate 31250baud ?
Maybe he add the time of each action on his fonction , i'm right??
Now, with your help i know what i need to do to send data in my JUNO60
Arduino must generate a clock at 31250hz on one PIN
a second PIN must send DATA (Start bit, Data Bits,Parity Bit and Stop Bit) in Serial at the same frequency and synhcro with the clock
And a third PIN to latch the hardwareflow control.
Then i could use this part of code to generate the right "polarity" of my bit
Code: [Select]
void SWprint(int data)
  byte mask;
  //startbit
  digitalWrite(tx,LOW);
  delayMicroseconds(bit9600Delay);
  for (mask = 0x01; mask>0; mask <<= 1) {
    if (data & mask){ // choose bit
     digitalWrite(tx,HIGH); // send 1
    else{
     digitalWrite(tx,LOW); // send 0
  //stop bit
  digitalWrite(tx, HIGH);
mikkelb
Hi Xarolium
Did you ever get this project working? I am trying to do the same thing at the moment, and I'm having quite a bit of problems, so if you've had any luck, I'd like to hear about it. (See http://forum.arduino.cc/index.php?topic=174173.msg1295934#msg1295934 for details)
Cheers
Mikkel
