Topic: CD74HC4067 Multiplexor. Is Resistor important? (Read 3642 times) previous topic - next topic
Laktica
hi everyone
just a quick question, specifically about a multiplexer but may just be a 'rule of thumb' for many ICs
with the  CD74HC4067E PDIP
Ive got a 100nF cap accross the power
but do i need a resistor along the 'enable pin to ground' connection
the schematic on the single SMD CD74HC4067 board here:  http://www.sparkfun.com/products/9056
has a 10k resistor
but the same chips here on a 3 chip board dont: http://mayhewlabs.com/products/arduino-mux-shield
is this resistor important??
tried searching and people mention building your own mux ect but no specifics on the resistor
thanks everyone
Grumpy_Mike
#1
Nov 03, 2011, 11:10 pm Last Edit: Nov 07, 2011, 02:19 pm by Grumpy_Mike Reason: 1
Logic chips like this can have the pins directly connected to either voltage rail. However a 10K to ground makes it look like a logic zero but allows you to easily pull it high later if you want to connect a signal to it.
Laktica
Thanks! so I know its not essential, I'm just going to connect them direct to ground for now, as thats ok
but if I decide I want to enable/disable the chips for some reason, I add a resistor to ground ( is 10k enough for two chips?)  so its enabled by default but use a 5v 'digital out pin to 'HIGH' to this enable wire to dissable the chips?
have i got that right?
Grumpy_Mike
Yes that is right.  :)
Quote
Well if it was me I would use 1K resistors to pull down.
