Hope someone can help me out with this. I have two arduinos in a master/slave relationship. The slave has a DS18B20 temp chip (running in parasite mode). It continuously polls the chip for the temp and waits for a request from the master. Here's a code snippet from the slave sketch:
void setup(){
Wire.begin(4); // join i2c bus with address #4
get_temp();
Wire.onRequest(requestEvent); // acknowledge a poll from master
delay(100);
void get_temp()
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
byte i;
byte present = 0;
byte data[12];
byte addr[8];
char charTemp;
if ( !ds.search(addr)) {
ds.reset_search();
Serial.print("bad address");
return;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.print("CRC is not valid!\n");
return;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
LowByte = data[0];
HighByte = data[1];
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
//get the whole and fraction in Celcius
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
Temp=(data[1]<<8)+data[0];//take the two bytes from the response relating to temperature
Temp=Temp/16;//divide by 16 to get pure celcius readout
Temp=Temp*1.8+32; // convert to Fahrenheit
void requestEvent()
INPUTFloatPtr = (byte*) &Temp;
Data[0] = INPUTFloatPtr[0];
Data[1] = INPUTFloatPtr[1];
Data[2] = INPUTFloatPtr[2];
Data[3] = INPUTFloatPtr[3];
Wire.send(Data,4);
Now, the master code reads the temp from the slave and posts the current temp as well as the high and low. The problem I've been having is that I occasionally get an invalid temp (such as 31.9, -2106.5, 526.8, etc.) This is measuring an aquarium water temp. That by itself would not be a big problem as I have attempted to put code in the sketch that compares the current temp reading with the last reading and ignoring any reading that is more than one degree more or less than the previous reading. Here's a code snippet from the master sketch:
i = millis()/1000;
poll_slave(); // get temp from slave
lcd.cursorTo(0,0);
lcd.print("Tmp:");
lcd.print(floatToString(buffer,temp,1)); // convert temp from float to string and print it
// compare to high and low
if (temp > HiTemp) // update high temp
HiTemp = temp;
if (DisplayHour < 10)
sprintf(Hibuffer, "%01d:%02d%c%c%d/%d",DisplayHour, minute, ampm, ' ', month, dayOfMonth);
sprintf(Hibuffer, "%02d:%02d%c%c%d/%d",DisplayHour, minute, ampm, ' ', month, dayOfMonth);
// print high temp and time of high
lcd.cursorTo(1,0);
lcd.print("Hi ");
lcd.print(floatToString(buffer,HiTemp,1)); // convert temp from float to string and print it
lcd.print(" ");
lcd.print(Hibuffer);
if (temp < LoTemp) // update low temp
LoTemp = temp;
sprintf(Lobuffer, "%01d:%02d%c%c%d/%d",DisplayHour, minute, ampm, ' ', month, dayOfMonth);
sprintf(Lobuffer, "%02d:%02d%c%c%d/%d",DisplayHour, minute, ampm, ' ', month, dayOfMonth);
// print low temp and time of low
lcd.cursorTo(2,0);
lcd.print("Lo ");
lcd.print(floatToString(buffer,LoTemp,1)); // convert temp from float to string and print it
lcd.print(" ");
lcd.print(Lobuffer);
void poll_slave()
Wire.beginTransmission(4);
Wire.requestFrom(4, 4);
if(Wire.available())
int i = 0;
while(Wire.available()) // slave may send less than requested
data[i] = Wire.receive();
i = i + 1;
union temp_tag {
byte temp_b[4];
float temp_fval;
temp_union;
temp_union.temp_b[0] = data[0];
temp_union.temp_b[1] = data[1];
temp_union.temp_b[2] = data[2];
temp_union.temp_b[3] = data[3];
temp = temp_union.temp_fval;
Wire.endTransmission();
// attempt to trap invalid temps
if (FirstPass = true)
LastTemp = temp;
FirstPass = false;
if (temp > LastTemp + 1 || temp < LastTemp - 1) //temp needs to be a full degree +/- than previous reading to be valid
temp = LastTemp;
LastTemp = temp;
Now, the problem is the last few lines of code don't always catch a stray temp reading. Anybody got any ideas?
Thanx in advance.
