Pages: 1 [2]   Go Down
Author Topic: Small Arduino Replacement?  (Read 1605 times)
it's about 1/3 the size. Seems pretty good to me. Also the mini-uino was sitting at a little bit of an angle, so it does look a little bigger in the photo.
Sussex UK / CT USA
Forums forever
Ummm... so, revealing yet again my capacity to be dim... is the following more or less on target?
If I wanted to become a Teensy-phile, I....
a) "Once and for all", "do some stuff" to improve my basic Arduino development environment, and then, after that....
b) Using a Teensy is pretty much like using a "real" Arduino, an RBBB, etc?
That's not too terrible! <smiley-kitty>
I was afraid that the "upload the bootloader" stuff was something I had to do with each new Teensy as it came into use... somewhat along the lines of "formatting a disc".
Oh dear. Now I have to buy a Teensy, and lose a few days playing with ANOTHER "new toy".
Joking aside... always good to have alternatives... thank you for the link to the "how to", and, if you are reading, thank you to whoever wrote it!
(For new people reading this thread... and to check an assumption that doesn't worry me much, but hasn't been covered... And, when "switching" from working with, say, an RBBB to an Teensy, I'd also use "Tools | Board" to tell the development environment, just as I would if, say, switching from an Uno to a Duemilanova?
France
For small-size and Arduino compatibility, take a look at the Sparkfun ProMini.  Programming the ProMini is essentially the same as for the Uno, except that the programming interface can be removed when not needed.  They both use the ATmega328 chip.
The Teensy is extremely cool, but I rarely find myself needing the small size and built-in USB.
Here's a rough size comparison between an Uno and a ProMini.  The red board is the FTDI USB-to-TTL-serial programming interface:
Pittsburgh, PA, USA
I only know some basic electricity....
How much current do RGB leds draw at full brightness? That to me is a real limit and time to think about drivers or not.
Examples can be found at Learning in the Main Site and at the Playground
Correct, but!
This is also TRUE.  If I buy 5 Teensys, I need to plug each in and  click a button to upload the Arduino bootloader.  Once this is done, you don't have to do it again.
I believe the last time I did it, it took ~6 seconds.
Boston area, metrowest
Most LEDs are spec'ed for 20mA.
RGB, 20mA per color.
Dallas
Shannon Member
There are many more differences...
• Full speed USB (12 Mps) versus 115200 baud.  Transferring data between the board and the PC is much faster.  It is even possible for the board to detect when the PC has the port open.
• Hardware USART not used for communicating with the PC making it available for communicating with other devices.
• More PWM pins
• Few more I/O pins
• More analog pins
• Two 16 bit timers instead of one
• Less expensive
Yes.  As an added bonus, Teensyduino makes the IDE a bit friendlier even when used for non-Teensy boards.
For size reference here are the Arduino variants that I have and a couple of ATTiny boards.
From left to right:
1) Circuit board for the Femtoduino designed by Fabio Varesano. By far the smallest, but will not work directly with a breadboard. Needs an FTDI adapter.
2) Teensy 2.0. A little smaller than a Pro mini, more I/O pins, built in USB, and a couple dollars less.
3) Arduino Pro Mini 3.3V from Sparkfun. Standard Arduino. You need an FTDI adapter. I use this FTDI cable from Sparkfun.
4) ATTiny13/ATTiny25 board from AllgaierShops. Good for breadboard work, but no Ardunio bootloader so you need to use C compiler and an ISP programmer.
5) ATTiny2313 board  from AllgaierShops. Good for breadboard work, but no Ardunio bootloader so you need to use C compiler and an ISP programmer.
And my Mini-uino boards, 1.3" square, with ICSP pins for downloading bootloader via FTDI Breakout, or Arduino as ISP, or Mdfly programmer.
Ground next to each IO pin aslo.
Need to install ATMega328P-AU, 16 MHz xtal, two 22 pf caps, 3 100nF caps, 10K resistor, header pins to suit your needs.
Sussex UK / CT USA
Forums forever
For the sake of completeness, we ought to mention the Solarbotics Ardweeny. ($10) The PBC with the support circuits is barely larger than the DIL Atmega, and is soldered to its pins...
http://www.solarbotics.com/products/kardw/
... not that I think it is a GOOD design... but it is kind of fun!
So... anyone want to take on the challenge of doing that with one of the tiny square SMT Atmegas?  <smiley-kitty>
Pittsburgh, PA, USA
Yes, 5 RGB leds x 3 elements x 20mA = 300mA.... through the pins, should be a factor.
BTW I like the Teensy but I think I'd pop for the Teensy++. OTOH I have a UNO and breadboards....
Its rare (if at all) that all three colors of the RGB will be on at the same time.  Mostly just strobing really fast (6 ms on, 1-2 ms off) between colors.  So I don't think that excessive current output with be a problem....
Greenwood, Indiana
That should be ok. If more current is needed this shift register rocks http://www.nxp.com/products/automotive/logic/shift_registers/HEF4794B.html after that you'd need some UNL chips or discrete transistors.
If it was designed by man it can be repaired by man.
Pages: 1 [2]   Go Up
