Topic: Arduino Uno -> Arduino Mega (Read 2226 times) previous topic - next topic
swimfree2010
I am currently working on a project and noticed I may need to upgrade from Arduino Uno to Mega. If I am sending signals from my computer using uno with xbee controller, will the mega with the xbee receive all the information transmitted? Or will I need to get two mega's so one sends the signal while the other one receives it.
Thanks!  :)
Also I am still a bit confused with the pins on the arduino uno. What is the difference between digital and analog pins?
Grumpy_Mike
Anything you can do on a Uno, you can do on a Mega.
Well analogue pins allow you to read analogue values, that is continuously varying voltages. Digital pins allow you to read only logic levels or output logic levels.
Analogue pins can also be used as digital pins with the correct software.
tkbyd
With respect, Mike, in case anyone out there reads the wrong things into....
You don't need any "new" or "extra" software to use the analog pins as digital pins. You use the "ordinary" Arduino development environment. You just have to write your software, your program ("sketch") the right way.
The "analog pins", to a beginner, are pins that you can connect things to, things which will have a voltage between 0 and 3.3v is you have a 3.3v Arduino, 0 and 5v for the rest of us. And then, in your program, you do something like....
iTmp=analogRead(0);
... and that puts a number from 0-1023 (inclusive) into iTmp, depending on the voltage in the wire connected to the first analog input.
HOWEVER... you can also (but not at the same time as you are using A0- A5!) "pretend" that you have 6 extra digital input/ output pins called D14-D19. They work just like D0-D13.
So, if you attached an LED (and resistor) to the pin for analog 0, and connected them to ground, and did....
  pinMode(14, OUTPUT);
  digitalWrite(14, HIGH);   // set the LED on
  delay(1000);              // wait for a second
  digitalWrite(14, LOW);    // set the LED off
... then the LED would wink.
(It's not "all or nothing". You can mix and match. You could do the above and STILL use, say, analog 1 as an analog input.)
