Hello! I'm working with an array of Firgelli L12 linear actuators (
http://firgelli.com/products.php?id=41), 12 volts, integrated control option, 100 mm stroke length, and I'm trying to control the stroke position through PWM from an Arduino Fio. We're using the Fio with an XBee Series 1 wireless module because we want to be able to control the actuator extension lengths wirelessly using Grasshopper + Firefly. So far, setting up the Fio to talk to Firefly has gone relatively smoothly, but I'm having a funny issue with how the PWM signal maps to position. When I tested the actuator with my Uno, the relationship between signal and length was fairly straightforward (analogWrite 0 = fully retracted, analogWrite 255 = fully extended 4"). However, when I try the same code with the Fio, it will only extend to 3" with a signal of 255 instead of the full 4".
I think this is an issue of signal frequency; I adjusted the PWM signal frequency in my test code because the actuator requires a 1 kHz square wave using this example:
http://www.arduino.cc/playground/Code/PwmFrequency. This worked on the Uno no problem. I know that the Uno's clock speed is 16 MHz while the Fio's clock speed is 8 MHz, so (I believe) the frequency on each of the pins should be half of what's listed for the 16 MHz boards. Unfortunately, in that case, it seems like none of the standard dividers would provide a 1kHz wave. I tinkered with the test code a bit and found that whether I'm controlling the actuator with a signal of ~2000Hz or ~500Hz, the actuator is still only going out to 3" at the highest signal. I'm posting my test code below:
#define BAUDRATE 57600
setPwmFrequency(3, 8); //1953.125Hz?
setPwmFrequency(5, 64);//488.2813Hz?
setPwmFrequency(10, 64);//1953.125Hz?
Serial.begin(BAUDRATE);
analogWrite(3, 255); //should be at 4" extension, instead at 3"
analogWrite(5, 255);
analogWrite(10, 255);
delay(15000); //the delays are so long because of the travel time of the actuator
analogWrite(3, 1); //returns to more or less 0"
analogWrite(5, 1);
analogWrite(10, 1);
delay(15000);
void setPwmFrequency(int pin, int divisor) {
byte mode;
if(pin == 5 || pin == 6 || pin == 9 || pin == 10) {
switch(divisor) {
case 1: mode = 0x01; break;
case 8: mode = 0x02; break;
case 64: mode = 0x03; break;
case 256: mode = 0x04; break;
case 1024: mode = 0x05; break;
default: return;
if(pin == 5 || pin == 6) {
TCCR0B = TCCR0B & 0b11111000 | mode;
TCCR1B = TCCR1B & 0b11111000 | mode;
} else if(pin == 3 || pin == 11) {
switch(divisor) {
case 32: mode = 0x03; break;
case 64: mode = 0x04; break;
case 128: mode = 0x05; break;
case 256: mode = 0x06; break;
case 1024: mode = 0x7; break;
default: return;
TCCR2B = TCCR2B & 0b11111000 | mode;
I've tried tinkering with the frequency divider and the baud rate and nothing will get it to fully extend. Does anyone have any ideas of what I'm doing wrong? I'm not an EE, so please excuse my poor grasp of basic electric principles.
