Topic: fscale not in math.h? (Read 2574 times) previous topic - next topic
aefields
I tried using the fscale function from http://arduino.cc/playground/Main/Fscale
It results in an error:
'fscale' was not declared in this scope
As per the instructions, I have "#include <math.h>" at the start of my sketch.  The "get code" link goes to http://arduino.cc/playground/Main/Fscale?action=sourceblock&num=1  which has examples, but no link to a library.  Where is it?  How can I use fscale?
robtillaart
you must copy the fscale() function directly into your sketch, it is not in a library
(from the link)
Code: [Select]
float fscale( float originalMin, float originalMax, float newBegin, float
newEnd, float inputValue, float curve){
  float OriginalRange = 0;
  float NewRange = 0;
  float zeroRefCurVal = 0;
  float normalizedCurVal = 0;
  float rangedValue = 0;
  boolean invFlag = 0;
  // condition curve parameter
  // limit range
  if (curve > 10) curve = 10;
  if (curve < -10) curve = -10;
  curve = (curve * -.1) ; // - invert and scale - this seems more intuitive - postive numbers give more weight to high end on output
  curve = pow(10, curve); // convert linear scale into lograthimic exponent for other pow function
   Serial.println(curve * 100, DEC);   // multply by 100 to preserve resolution
  // Check for out of range inputValues
  if (inputValue < originalMin) {
    inputValue = originalMin;
  if (inputValue > originalMax) {
    inputValue = originalMax;
  // Zero Refference the values
  OriginalRange = originalMax - originalMin;
  if (newEnd > newBegin){
    NewRange = newEnd - newBegin;
    NewRange = newBegin - newEnd;
    invFlag = 1;
  zeroRefCurVal = inputValue - originalMin;
  normalizedCurVal  =  zeroRefCurVal / OriginalRange;   // normalize to 0 - 1 float
  Serial.print(OriginalRange, DEC);
   Serial.print("   ");
   Serial.print(NewRange, DEC);
   Serial.print("   ");
   Serial.println(zeroRefCurVal, DEC);
  // Check for originalMin > originalMax  - the math for all other cases i.e. negative numbers seems to work out fine
  if (originalMin > originalMax ) {
    return 0;
  if (invFlag == 0){
    rangedValue =  (pow(normalizedCurVal, curve) * NewRange) + newBegin;
  else     // invert the ranges
    rangedValue =  newBegin - (pow(normalizedCurVal, curve) * NewRange);
  return rangedValue;
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
aefields
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
