Loading...
Pages: [1] 2   Go Down
Author Topic: MILITARY CODING  (Read 1025 times)
Castlegar , B.C. , CANADA
Offline Offline
Newbie
An old dog learning new tricks !
View Profile
Boys :
 KNOW that this current technology is NOT " state-of-the-art " .  16 MHZ clocks , 8 BIT busses ?
Video games like PACMAN , GALAGA , ROBOTRON had multi-processor bussing that incorporated the likes of 85000 , 6502 processors !  Pipelining of the signals , was the KEY .        PARALLEL    PROCESSING  !
THAT  technolgy was the 1970's   ;    Babe !            8 bit busses , 16 Meg clocks , .....  What a laugh  .
 ALL of the OLD 8 bit IC's that was ready to throw away , are ALL coming back into play . NEW technology ;  NOPE  !     (  Don't be fooled !  )
 Only if the Arduino 2560 MEGA was available back then !         ( Circa  1980  )
Nearly  EVERY  Arduino program seen uses really long ( greater than 300Msec )  DELAYS  somewhere within .   WHY  ?     This   FREE programming  SPACE  is best used elsewhere ;   my point .....
 MILITARY  applications of the hardware had the performance " Throughput Delay " propogations testing of ANY device warranted . A simple IMPULSE measurement of an INPUT , the traverse time , thru to the OUTPUT measured in NanoSeconds .   Singular gates or complex CPU processors .       Simple enough .
THE   MAGIC :
  The HARDWARE devices had an actual FIXED time value as to their acquisition of a DATA value upon the initial impulse command . As most of these " smart devices " had an internal data LATCH incorporated , the devices could be " triggered " upon a signal to DO their thing while the software DID something else except WAITING around for an output from the triggered device afore mensioned . When the triggered device had performed its operation , it would provide a hardware level INTERRUPT ( latched ) that would be dealt with in the order of the main program .
 Simple stuff that hasn't changed since the 8080 days .     BUT :  The MILSPEC  programming does something a bit different ...........
  Having MEASURED the response times of the peripheral devices of the system ( to the NanoSecond ) , commonly addressed device propogation lengths to exercise their respective routines ; can be used as " program delay functions " for other sub-routines of the major program .
   MULTI-TASK     by filling up the TIME  SLOTS  normally used by ,   :  " DELAY commands " !   Gotta use triggering FLAGS .
   FREE   THE    ARDUINO    !     The I/O pins anyway . DO the APPS in " hardware " to   MAKE  IT  SO . ( Jean Luc Picard )       Dedicate this ;   MICRO-CONTROLLER  to its task .    Unlike its larger brother of a " Central Processing Unit "   ( CPU )  .     Get over the difference between these guys .
 MILSPEC may not be necessarily superior to any others ; BUT they are     BETTER  FUNDED  than anyone else !
Hardware guys had to deal with along the way .........................
 The  " Software Guys "  used to fill in the tiny TIME  SLOTS  in the programming .  Apparently , projects are still flying !
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
What you are describing is merely the "Blink without delay" code example, many of us use that regularly and we attemtpt initiate newbies into it as well.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
BLINK without Delay ?    A lot of us did in the 1st Iraq War Opening Night .
 Kind Sir .      One of the projects at LRS Houston was the SCUD shooting Patriot ABM .     When , in the famous 1991 green night vision news clip when one " actually turned 30 degrees " to intercept the SCUD , there were a LOT of us that were surprised !
    My little part was the STEPPER motor gimbal thingy .   Did it in EPROM      1 - ( E ^ (-T/RC))   !
  GPS   was about 4 years later .....................Dude .
  Britain ,    WAS   next on the platter .
 ARDUINOS   are a great controller .   I   LUV 'em !     Please don;t understand .
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Ok, then I guess we're in agreement.
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Here I am wondering if the OP is actually Dennis Markuze/David Mabus, somehow "on leave" (ugh)? Or maybe the OP is a SPAM author? The weird formatting, the random capitalizations, the misspelled wording, the general ranting tone...hmm.
smiley-grin
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
smiley-grin
Battle fatigue maybe? War wound?  smiley-wink
Either way I respect anyone who actually served in a combat zone.
Lefty
Logged
Offline Offline
Newbie
View Profile
Boys :
 Sorry for the " rant " that retroLefty  amuzed to .    I  was not aware of the mis-schpelling though . Canadian ; Eh ?   The " other-side-of-the-trax " cousins that you guys tend to forget about unless the BUCK is around par !   Then you tend to worry ; a LOT .
 Only to be known that the team at LRS did some stuff back then to make those little 1 inch steel cubes within the nose cone , disperse ; kinda " on demand " .  SCUDs begone .  Testing in Northern Alberta that spring whereby the Patriots were launched from the bellies  of the B-52's only yielded the same old reponse . The " guidance " was dubious at best . Cold Lake Alberta is not so cold in the summer . The NEW CF-18's were cool to watch ; and one CAN actually fit 7 city busses in an end-wise fashion within the cargo bay of a B-52 .    174 ft. 10 in. wingspan to boot .
 Lefty is right in assuming that I was NOT there in Iraq . He is also right in assuming that this corrospondence is a type of " war wound " . The wound is ONLY of the heart though . It has to do with ALL of our boys and girls that HAD TO serve over there in the first place . George's " weapons of MASS distraction " .    OIL ,   OIL     ,   OIL    babes .   Look at the NEWS tonight and SEE what is next for a SECURE SUPPLY to Canada's OIL legacy and about how that will be reaped . ( read RAPED ) XLPipeline thru Nebraska's water aquifer . ( state wide aquifer )    Now , that is the raping of the land !
 George Custer and the rest of the 6th Cav is rolling over in their graves as the pipeline goes right past the knoll !  What a shame .
 I need another " single malted " .    Later Gents .     This was a funny THREAD .     Kudos !
Logged
Offline Offline
Newbie
View Profile
REPLY to SELF :
 Please beware that this stuff IS being monitored .  Funny about just how sensitive the Information from the Military Channel  on the satellite IS !
 My previous comments about Cold Lake Alberta ;  great fishing !   SOuth of town about 45 Km is the area .
 CF-18's . The Horneys .   Yeah . They show up in town every once in awhile on a refuelling thing between CFB Comox and Calgary .
 7 busses fitting into a B-52  ?    Some guy on SPIKE  TV  did it a few weeks ago !   I didn;t think that there was that much room in there .    174 ft. 10 inch wingspan is published in JANES .
 Gimme a break .
BEING   BLOCKED  from a lot of websites including this one for the past hour or so is a VIOLATION of my rights though .   Foriegn country Email destined to another foreign country , NONE of it within the USA ?
Confused at best .  Maybe this thread is NOT so funny after all !
Logged
Netherlands
Offline Offline
Sr. Member
A naughty mind is a joy forever.
View Profile
Yep, I remember those B52s, man did I have a crush on Kate and Cindy.
Private Idaho, rock lobster, 53 Miles west of venus, whatever had happened during the daytime, hearing those songs on my tiny walkman (it never really walked by the way) assured I could sleep at night and had the sweetest dreams.
Anyway, whut was I talking about ?
Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
Is this an example of windtalking, google translated from Navajo to English, and back to English via Japanese?
Logged
Per Arduino ad Astra
0
Offline Offline
Sr. Member
View Profile
Quote
Yeah!
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
Quote
A B-52 does not have a cargo bay it has a bomb bay and you would not be able to get even one large mini-van in there.  I did hear stories about an MG being smuggled in one (probably an urban myth) but even that would have been a tight fit.
Edit:  Here's a picture I found.  The photographer was standing with his back at one end and with his feet on the tarmac, not on a ladder.
http://www.flickr.com/photos/maleny_steve/3738286988/in/photostream/
Don
« Last Edit: November 17, 2011, 09:19:05 pm by floresta » Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
The BUFF's* bomb-bay is only 2.5 metres wide.
Those are pretty narrow buses.
* It is Big, it is Ugly, but it isn't all that Fat. I have no idea what the other F stands for.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Flyer, of course smiley-yell
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Of course!
I thought it was "Fellow"
Logged
Pages: [1] 2   Go Up
Print
Jump to:
