Topic: New with sensors (Read 3297 times) previous topic - next topic
tege88
Hi guys,
I really need your help.
Basically I have this Sharp sensor
http://docs-europe.electrocomponents.com/webdocs/0a71/0900766b80a71447.pdf
and what I need it to do is when it detects any movement, trigger a fan for 5 seconds
then sensor is on pin 0 and the fan is on pin 13
Please help.
Thanks
Graynomad
That sensor has an analogue output so you have to run it into one of the analogue pins, not pin 0.
Then read the value with analogRead(), decide if the value is different to the last reading and if so start the fan and also start a timer. After 5 seconds stop the fan.
______
Rob
tege88
Thanks for getting back to me.
Okay so how would I go about programming that?
int sensorPin = A0;    //sensonr
int fanPin = 13;      // fan
int sensorValue = 0;  // variable to store the value coming from the sensor
  // declare the ledPin as an OUTPUT:
  pinMode(fanPin, OUTPUT);
  // read the value from the sensor:
  sensorValue = analogRead(sensorPin);
  // turn the ledPin on
  digitalWrite(fanPin, HIGH);
  // stop the program for <sensorValue> milliseconds:
  delay(sensorValue);
  // turn the ledPin off:
  digitalWrite(fanPin, LOW);
  // stop the program for for <sensorValue> milliseconds:
  delay(sensorValue);
Graynomad
What you have there is a lot different to the problem stated in the OP.
If you want the LED to flash at different speeds according the the value read from the sensor that yes that looks good.
_____
Rob
tege88
erm no hahha
I just want it to go on for 5 secs when the sensor picks something up,
so far nothing is happening :(  at all
Graynomad
So what's with the code? Just print the values you're getting from the sensor to the serial monitor to get an idea of what's happening.
______
Rob
tege88
tege88
when I do it, it just keeps coming up with 0
Graynomad
Post the actual code you are using and a schematic or description of the circuit you have.
______
Rob
Erni
The sensorvalue could be between 0 and 1023, so you should use
unsigned long sensorValue = 0;
and your test for starting the fan somthing like
if (sensorValue >500){
delay(5000);
tege88
int sensorPin = A0;    // select the input pin for the ir sensor
int fanPin = 13;      // select the pin for the fan
delay(5000);
Graynomad
That code doesn't print anything, refer to reply #8.
______
Rob
tege88
hey, yea sorry,
I managed to get it printing now,
now im trying to get this to trigger the thing for light/fan  for 5 seconds when it senses anything
Graynomad
Well when you get the urge to share some data we'll be here :)
_____
Rob
tege88
that was the code I used to get it to read the IR pin
int IRpin = 0;                                    // analog pin for reading the IR sensor
  Serial.begin(9600);                             // start the serial port
  float volts = analogRead(IRpin)*0.0048828125;   // value from sensor * (5/1024) - if running 3.3.volts then change 5 to 3.3
  float distance = 65*pow(volts, -1.10);          // worked out from graph 65 = theretical distance / (1/Volts)S - luckylarry.co.uk
  Serial.println(distance);                       // print the distance
  delay(100);                                     // arbitary wait time.
