Loading...
Pages: [1]   Go Down
Author Topic: addressable I2C i/o chip recomendation?  (Read 1023 times)
Offline Offline
Full Member
View Profile
Can any one recommend an addressable I2C chip for driving an LED.
My requirements are: set the address (0-127), drive a single LED (on /off), low cost.
(I found this http://uk.farnell.com/jsp/displayProduct.jsp?sku=1564917&CMP=e-2072-00001000&gross_price=true, which I think would be suitable except I do not believe you can set the address)
cheers.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
something like - http://www.sparkfun.com/products/8130 - ?
datasheet - http://www.ti.com/lit/ds/symlink/pcf8575c.pdf -
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Full Member
View Profile
Thanks for the suggestion but the datasheet says:
Quote
Address by Three Hardware Address Pins for
Use of up to Eight Device
I ideally need up to 127 devices
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
you can add 8 of such chips, every one can control 16 lines (=16 leds)
8 x 16 = 128 , so you have one to spare.
Another option might be the centipede shield - http://macetech.com/store/index.php?main_page=product_info&products_id=23 -
IIRC there can be two on the I2C bus (eight in fact but the library only support 2, but you may fix that smiley-wink
2 x 64 = 128
hopes this helpes,
update: removed wrong info  smiley-red
« Last Edit: November 17, 2011, 03:10:31 pm by robtillaart » Logged
Rob Tillaart
SF Bay Area
Offline Offline
Edison Member
Arduino Ninja
View Profile
WWW
Only 8 MCP23017 chips per bus, and each Centipede has 4 chips smiley
Logged
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Use MAX6953. One chip. Control 140 LEDs.
I2C interface.
One current set resistor.
http://datasheets.maxim-ic.com/en/ds/MAX6953.pdf
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Full Member
View Profile
sorry I should of been more clear - I need around 120 individual units, after further research I guess maybe ATtiny45's might be the solution (creating BlinkM clones) although a little overkill for my application, as I only really need a single colour LED (possibly with with PWM).
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Here is an alternative to BlinkM:
http://www.seeedstudio.com/depot/grove-chainable-rgb-led-p-850.html?cPath=156_157
You can build it yourself, but it won't be much cheaper. Plus, I think you may get a discount when you buy 120 of them.
Logged
Colorado
Offline Offline
Edison Member
Reviving dead brain cells with Arduinos.
View Profile
Do you have to be able to set an address for each LED?  What if it's just a 2-wire communication where you shift data out to the entire string?
Take an RGB LED - $0.12 (1000 minimum)
with a WS2801 - $0.16 (1 to 1000)
1x 0.1uF cap - $0.03 (100 - 499)
3x resistors - $0.02 (100 - 499)
PCB - $0.72 (12 - I created my own through fab house)
And you end up with a pixel cost of $1.09 - multiply that by however many you want.  Your Arduino just needs to provide a DATA and CLK source and you're done.  You can either provide VCC/GND from the Arduino (3.3V up to 5.5V), or from an external supply.
Worth nothing: this is the exact same thing that many 5V addressable RGB strips are made of, except for the flexible and adhesive backing.
Logged
Colorado
Offline Offline
Edison Member
View Profile
Actually, never mind.  You indicated you're creating BlinkM clones, so these might not be sitting together in a long string.
Logged
Offline Offline
Full Member
View Profile
thanks for the replies guys, yes the reason I'm thinking blinkM style devices is because my project requires a tree/branching style layout  - and so chainable units would make for somne ugly wiring.
Logged
Colorado
Offline Offline
Edison Member
View Profile
Then, if you're talking each unit being on its own, what does it matter if they're addressable or not?  Just program each one and go to town with them.
Logged
Offline Offline
Full Member
View Profile
As I need to be able to turn each unit of and on independently, from the control application.
Logged
Colorado
Offline Offline
Edison Member
View Profile
So they will be wired together then, just not in a long continuous string, correct?
You could still do strings, just several of them going to individual branches.  Each one would need 2 wires from the controller (NOT including VCC/GND).  I get what you're saying though.
Logged
Pages: [1]   Go Up
Print
Jump to:
