Loading...
Pages: [1]   Go Down
Author Topic: 'LOW' was not declared in this scope  (Read 508 times)
Loughborough, UK
Offline Offline
Full Member
Bloody semicolon
View Profile
I am splitting my code up into tab (so seperate .cpp and .h files) to keep things organised, then using #includes to bring it all together.
I'm aware of the need to "#include <WProgram.h>" because I'm using "analogRead()", however I am getting the following compiler error on a different object.  I'm assuming it's a similar problem that I need to include a random header because it's not in a .pde file, and LOW is a standard declaration.
Does anyone know the solution?
Quote
In file included from pointers.cpp:4:
/REALTIME.h: In constructor 'CTime::CTime()':
REALTIME.h:7: error: 'LOW' was not declared in this scope
pointers.pde is the main file
realtime.h and .cpp are an included object that has the following line in it:
Code:
ledState=LOW;
To all those helping, many thanks.  I have Googled this but found nothing, nor anything in the forums.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
I suppose you could just try adding a random header file. When you choose the right random header file (wiring.h), the results would be better.
Logged
Loughborough, UK
Offline Offline
Full Member
Bloody semicolon
View Profile
Good idea, just tried every header file in /hardware/ardiono/cores/ardiuino/ which is where WProgram.h is.  No luck.
EDIT:
Found the problem, the variable I was setting to LOW was a global variable.  For some reason it didnt like this, so I have made it a local variable & now it compiles.
So, dodgy error message; LOW is valid, what you're assigning it to is not (in my case anyway!0
cheers
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Never heard of this before, that you can't assign LOW to global variables.
Logged
North Queensland, Australia
Online Online
Edison Member
View Profile
WWW
Too true, scope of objects plays no part in this. Adding the header include after the variable declaration will produce this.
Logged
Pages: [1]   Go Up
Print
Jump to:
