Topic: Ultrasonic ping-pong game (Read 2548 times) previous topic - next topic
Lisax
Nov 17, 2011, 05:11 pm Last Edit: Nov 17, 2011, 05:16 pm by Lisax Reason: 1
Hi, just want to share with you a little project I finished few days ago. Its classic Atari pong game but controled by two ultrasonic range sensors (SRF05).
http://youtu.be/6JomPCmY5RQ
Source code for arduino
int ultraSoundpin1 = 7;
int ultraSoundpin2 = 5;
unsigned long ultrasoundDuration;
  // switch pin to output
  pinMode(ultraSoundpin1, OUTPUT);
  // send a low, wait 2 microseconds, send a high then wait 10 microseconds
  digitalWrite(ultraSoundpin1, LOW);
  delayMicroseconds(2);
  digitalWrite(ultraSoundpin1, HIGH);
  delayMicroseconds(10);
   // switch pin to input
  pinMode(ultraSoundpin1, INPUT);
  // wait for a pulse to come in as high
  ultrasoundDuration = pulseIn(ultraSoundpin1, HIGH);
  // output
  Serial.print(ultrasoundDuration);
  Serial.print(";");
  pinMode(ultraSoundpin2, OUTPUT);
  digitalWrite(ultraSoundpin2, LOW);
  digitalWrite(ultraSoundpin2, HIGH);
  pinMode(ultraSoundpin2, INPUT);
  ultrasoundDuration = pulseIn(ultraSoundpin2, HIGH);
  // output
  Serial.print(":");
  delay(50);
Here is source code for computer application (made in Delphi) are here
Delphi and arduino source codes together with all files which are necessary to compile it are here
To compile delphi app you will need com port component. You can download it here.
wiz
No replies yet! so I'll post one. That is neat, and with the Delphi app as well. I will try the Pascal  code in Lazarus/fpc when I get a chance.
AWOL
Somewhat shorter: (uncompiled, untested)
int ultraSoundpin [] = {7, 5};
  Serial.print(ping (ultraSoundpin [0]));
  Serial.print(";");
  Serial.print(ping (ultraSoundpin [1]));
  Serial.print(":");
  delay(50);
unsigned long ping (int ultraSoundpin)
  pinMode(ultraSoundpin, OUTPUT);
  digitalWrite(ultraSoundpin, LOW);
  digitalWrite(ultraSoundpin, HIGH);
  pinMode(ultraSoundpin, INPUT);
  return pulseIn(ultraSoundpin, HIGH);
liuzengqiang
Awesome!
Lisax.left_brain, you enjoy beating Lisax.right_brain? ;)
Lisax
wiz: Yeah, try it, its really fun to play. All works great, there is just slight problem with sensors, they return a bit unstable values so paddles are shaky. I solved this problem in my delphi app with making average from last few values, that came from arduino (number of values from which should be the average made is in constant called fluidity). Or you can try another type of sensor.
Here is graph of values (target is static)
AWOL: Thank you, it looks way more elegant now
liudr: Yes, my right part of brain was really happy when it won :D
Si
Thats a great idea.
Well done. :)
I write books about Arduino and Electronics: http://simonmonk.org
